Intel vPro® Platform
3049 Discussions
Cert Trouble Provisioning Legacy System
I have an HP 8000 Elite Tower with AMT 5.2.1088 and I'm trying to provision it in my SCCM environment. After making the connection and pulling the profile from SCS, the log says that there is no valid PKI certificate, but there is an it matches the thumbprint of the one that I added to AMT. I have provisioned multiple AMT 9 systems without a problem and I have double checked that I have set this system up with the same options. Does anyone know if the cert requirements are different on older systems, or any reason this might be happening?
We're using a self-signed certificate. I have Intel SCS Console on my server and provision using the Intel Configurator and ACUConfig.exe /lowsecurity /output console /verbose ConfigViaRCSOnly SCSserver profile
Error shown here.
Exit with code
75.
Details: Failed to complete remote configuration of this Intel(R) AMT device.
Initial connection to the Intel(R) AMT device failed.
A valid PKI certificate was not found in Certificate Store of the user running the Remote Configuration Service.
I've double checked my certificate to make sure that I entered the
C:\Users\administrator\Desktop\intelscs_9.1.2.74\IntelSCS\Configurator> ACUConfi
Starting log 2014-12-15 13:38:06
Set compatibility mode to 9.0.
Connected to the Intel(R) Management Engine Interface driver, version
5.2.0.1008
Intel(R) AMT in PROVISIONING_MODE_ENTERPRISE
5.2.0.1008
Failed to get data from the firmware.
(0xc0000022)
Calling function Discovery...
Calling function GetLocalSystemAccount over MEI...
5.2.0.1008
Error: failed to retrieve Local System Account using MEI; error code - 0xc0004a7
a
Host Based Setup is not supported
Function Discovery ended successfully
GetHostAndMEInfo output data:
IsAMT:True,
isAmtCapable:False,
isEnterpriseMode:True,
configurationMode:0,
isRemoteConfigEnabled:True,
AMTversion:5.2.50,
isMobile:False,
provisioningTlsMode:2,
uuid:DCCEB490-D2A7-11DE-BBDA-8579DE5AD8D3,
isClientConfigEnabled:False,
hostBasedSupport:False,
configurationState:1,
FQDN:,
embeddedConfigurationAllowed:False.
isLANLessPlatform:False.
PKIDNSSuffix:test.local
:Starting Remote configuration...
***** Start RemoteConfiguration ******
AMT Status code - An internal error has occurred in the Intel AMT device. This m
ight indicate an interface error, or an application error.
(0xc0004269)
(0xc0000022)
Get AMT Name:Failed to get the hostname (AMT).
Changing AMT state from IN-provisioning to Pre-Provisioning in order to set AMT
OTP
***** Start StopConfigurationInt ******
Calling function StopConfiguration over MEI...
5.2.0.1008
a
failed to initialize WSMAN client
Waiting for FW to move to Pre-Provision state(0)...
5.2.0.1008
a
This system was already unconfigured. The system was successfully put in the "Pr
e Provisioned" state and the Intel(R) AMT interfaces are now closed.
***** END StopConfigurationInt ******
5.2.0.1008
Moving to Pre-Provisioning state failed. An old OTP exist in local settings stor
e.
***** Start StartConfigurationInt ******
5.2.0.1008
Activate Intel(R) AMT configuration:
(0xc0000050) (Success.
Waiting for FW to move to In-Provision state(0)...
The Start configuration operation completed successfully.
***** END StartConfigurationInt ******
RCSaddress=cm.test.local, RCSWMIUser=, RCSProfileName=inteltest
HP8000Elite.test.local
RCSaddress=cm.test.local, RCSWMIUser=, UUID=DCCEB490-D2A7-11DE-BBDA-8579DE5AD8D3
, ConfigMode=2, PID=, RCSProfileName=inteltest, AMTVersion=5.2.50, OldADOU=, Con
figure AMT Name= True. Configure AMT IPv4= True. Source For AMT Name= Host Name-
HP8000Elite Domain Name- test.local . Default OS Name= Host Name- HP8000Elite D
omain Name- test.local . Host IPv4= IPv4 Address- 192.168.1.207 IPv4 SubNet- 255
.255.255.0 IPv4 Primary DNS- 192.168.1.10 . Configure AMT IPv4 to DHCP mode= Tru
e. AMT IPv4= IPv4 Address- 192.168.1.207 .
***** END RemoteConfiguration ******
Exit with code
75.
This appears similar to this thread, which was never answered.
/message/242703# 242703 https://communities.intel.com/message/242703# 242703
