Intel vPro® Platform
3064 Discussions
Desktop not Manageable once turned off
Having an issue with VPRO and i cant quite figure it out. I Am using Altiris Out of Band Management to manage the VPRO machines. I Can provision through a USB Key, I can also connect to it through Real Time System Manager using AMT, i can even specify to do a reboot and to boot into the BIOS and i can watch this happen. The problem is, is if i shut down the computer i loose complete connection to it. Once the machine is powered off and is out of band i can no longer manage it. I set the Power Options to S0 and still get the same results.
I dont get why i cant ping the device or connect it once it is powered off. Any ideas on what i can try?
