Intel vPro® Platform
3080 Discussions
Diffrence between vPro and Non-vPro Intel Processors? Is there a performance diffrence?
SKand7
What is diffrence between vPro and Non-vPro Intel Processors? Is there a performance diffrence? if yes how much is the performace diffrence?
AP16
Valued Contributor III
Main difference at CPU level is support for storage of PKI certificates inside a special memory area in CPU, protecting them from unapproved extraction and 'cold memory boot' attacks. Also, all vPro CPUs are compatible with Trusted Execution, special mechanism by which CPU checks the BIOS/EFI/OS boot loader configuration against defined policy, effectively blocking PC/server boot at early stages in case of unwanted changes of environment (Biruses, boot loader level rootkits, third-party boot managers, attempts of boot from removable media and so on). There is no difference in performance.
