Intel vPro® Platform
3067 Discussions
Does anyone have the experince to deploy AMT in vLan?
I need to set up an AMT 3 POC at EU site which need VLAN support. I know that AMT 3 support VLAN, can find an config item at MEBx, what i want to know is does AMT have some limitation to supporting VLAN, anyone have this experince to share the BKM how to config AMT within VLAN?
thanks
-Jen
Brian_Cockrell
You do NOT need to configure the AMT 3.0 VLAN ID setting to manage clients deployed in a VLAN. The VLAN ID setting is used when you want to place all AMT traffic in a separate VLAN from the host OS. Separated traffic is not a typical configuration and would likely not be needed for your POC.
Thus will be good, i dont need to do extra settings for the AMT within VLAN. thanks.-Jen
