Intel vPro® Platform
3043 Discussions
EMA 1.7.1 TLS-PKI Cert Issue
carlosmnzn
Hi, I was reading about ACM provisioning in Intel EMA 1.7.0.0 version had a bug where certificate chains were not retrieved from the database in the correct order, which could prevent certificate-based PKI-TLS (admin control mode) provisioning from working in certain cases.
We already have the new version (1.7.1.0) and this issue still appears.
We have tried to provision Intel AMT later than 12.0.45 version devices with a valid certificate and doesn't work.
On platform manager we can see this:
Thanks, regards.
carlosmnzn
Hi @JoseH_Intel
After several tests we realized that enterprise root certificate import is required for the new version, so we additionally import the root certificate and it works.
We thought that only an Intel AMT PKI certificate was necessary because 1.6 and previous versions work without loading the enterprise root certificate.
Thanks and regards.
JoseH_Intel
Hello carlosmnzn,
Thank you for joining the Intel community
We appreciate you bringing this to our attention. Could you share the following info:
  • Current certificate provider
  • Attach screenshot of the EMA console > Settings > certificates
  • Are you using CIRA or TLS security?
  • Where did you read about this cert chain issues on EMA v1.7.0?
Jose A.
carlosmnzn
Hi @JoseH_Intel, I'm going to answer your questions in order:
1) The current certificate provider is GoDaddy. This certificate works correctly at the 1.6.X version of Intel EMA.
2)
3) We use CIRA. In fact, in client mode, the devices are provisioned well and with the CIRA connection activated.
4) I read it in the pdf of 1.7.1.0 release notes, concretely at point 2 of  2 What's New in this Release?
I'm not sure if this issue is the one we are being affected by but I think so...
I will appreciate any information about it that can fix or tell us if it could be a bug or something similar because we have no idea what can be going on.
Thanks so much, regards.
Carlos M.
JoseH_Intel
Hello carlosmnzn,
Thank you for your updates. I am not quite understanding well what your issue is. You say your endpoints are successfully provisioned and the CIRA connection is working fine. All this is working on EMA v1.6. So, is your issue related to EMA 1.7.1? Are you trying to provision any newer systems?
In the Release Notes > What's new section specifies that the certificate chain issue is corrected on this version (1.7.1). If you are finding issues when provisioning any new system, please attach the EMA log so we can take a look at the error shown.
Jose A.
carlosmnzn
Hi @JoseH_Intel
Yes, the issue is related only to the 1.7.1.0 version. The EMA Server is running on Windows Server 2022 and the new device we are trying to test on this version has a 12.0.97 Intel AMT version with Windows 10 pro and is an intel vpro i5 8th gen device...
And yes, that's why I think the problem of the 1.7.0.0 still continues on 1.7.1.0 although in the release notes it appears that it has been fixed. Maybe I could be wrong, I only want to make sure the problem is not ours.
What kind of logs exactly do you want me to attach? all logs at the path C:\Program Files (x86)\Intel\Platform Manager\EMALogs or any specific?
Thanks so much again, regards.
JoseH_Intel
Hello carlosmnzn,
Thank you for the extra details. You stated to have EMA installed on a Window Server 2022 system. Looking at the supported OS for EMA, Win Server 2022 is not within the list. This might be generating issues during provisioning.
https://downloadmirror.intel.com/646990/Intel_EMA_Release_Notes.pdf#page=11
About the EMA logs, you can attach all of them.
Jose A.
carlosmnzn
Hello @JoseH_Intel
Ok, let me try first to install EMA on a windows server 2019, when I have done the new results I'll inform you and if the issue continues I'll attach the logs.
Thanks for your support again, regards.
SergioS_Intel
Hello carlosmnzn,
We will be looking forward to your updates and the logs.
Sergio S.
JoseH_Intel
Hello carlosmnzn,
I am just following up to double-check if you were able to gather the requested information. Otherwise let us know if you require more time to accomplish this.
Jose A.
carlosmnzn
Hi @JoseH_Intel
Thanks and regards.
SergioS_Intel
Hello carlosmnzn,
We appreciate the additional information, please let us know if you need additional assistance or if we can close this thread.
Sergio S.
carlosmnzn
Hello Sergio.
All good. You can close this thread.
Thank you and Joseph for your quick assistance, regards.
