Intel vPro® Platform
Intel Manageability Forum for Intel® vPro Fleet Services, EMA, AMT, SCS & Manageability Commander.
3088 Discussions
EMA API: AMT Setups section data model
maksymr
Greetings,
I have a question about AMTSetups section of AMT API:
In swagger, the model of ExtraAMTInfo is described as follows:
But the real result that I retrieve provides escaped json data as part of Name/Details fields in nested ExtraAmtInfo objects.
So my question is - is there any kind of model these name/details fields would match, if they contain json?
It is indeed a string in all cases, but I want to understand if there can be a reliable solution of mapping this data using some kind of pre-defined contract.
Thank you
Suneesh
Hello Maksymr,
Good day.
Please note that the scripts are intended as sample code, demonstrating various Intel EMA API calls and related operations. They are designed for reference purposes and should be customized to fit your specific use cases.
We recommend incorporating them into your own scripts, with necessary adjustments based on your requirements.
Suneesh
maksymr
Also, unrelated to AMTSetups section - There are properties like Brand, PlatformType, NodeIdentity, that also have numeric (or string with numeric values) fields, here's the example response from our EMA API:
  "EndpointGroupName" : "AllInGroup",
  "LastUpdate" : "2024-10-18T12:22:30Z",
  "MEVersion" : null,
  "ComputerName" : "LAPTOP-R0IQ9RGV",
  "Fqdn" : "LAPTOP-R0IQ9RGV",
  "PlatformType" : 1,
  "AgentVersion" : 11400,
  "AgentIdentifier" : 4,
  "MEFWBuildNumber" : null,
  "PowerState" : 0,
  "PowerStateUpdate" : "2024-10-18T12:22:22Z",
  "IsConnected" : true,
  "NodeIdentity" : 4,
  "IsAmtVersionValid" : null,
  "AmtControlMode" : null,
  "AmtProvisioningState" : null,
  "AmtProvisioningMode" : null,
  "IsCiraConnected" : false,
  "Brand" : 0
Is there a similar mapping available for these, as there is for the PowerState?
Thank you
Suneesh
Hello Maksymr,
Good day.
Suneesh
Suneesh
Hello Maksymr,
Good day.
We are following up on this. If further assistance is necessary, please do not hesitate to reply.
Suneesh
