Intel vPro® Platform
3049 Discussions
Match EMA Group permissions to IB and OOB endpoint operations
maksymr
Greetings,
Im working on EMA integration, and Im having some issues figuring out which Group permissions actually grant some of the EMA Rest API commands.
So, /api/latest/endpointGroups endpoint provides a following response:
"Permissions": {
"AllowWakeup": true,
"AllowSleep": true,
"AllowReset": true,
"AllowTcpCommunication": true,
"AllowAlert": true,
"AllowConsole": true,
"AllowKvm": true,
"AllowFileAccess": true,
"AllowWmi": true,
"AllowLocation": true,
"AllowP2P": true,
"AllowUserConsentKVM": true
And we're using these IB and OOB operations:
OOB:
  • /api/latest/endpointOOBOperations/Single/PowerOn
  • /api/latest/endpointOOBOperations/Single/Sleep/Light
  • /api/latest/endpointOOBOperations/Single/Sleep/Deep
  • /api/latest/endpointOOBOperations/Single/PowerCycle/OffSoft
  • /api/latest/endpointOOBOperations/Single/PowerOff/Hard
  • /api/latest/endpointOOBOperations/Single/Hibernate
  • /api/latest/endpointOOBOperations/Single/PowerCycle/OffHard
  • /api/latest/endpointOOBOperations/Single/MasterBusReset
  • /api/latest/endpointOOBOperations/Single/MasterBusReset/Graceful
  • /api/latest/endpointOOBOperations/Single/PowerOff/SoftGraceful
  • /api/latest/endpointOOBOperations/Single/PowerOff/HardGraceful
  • /api/latest/endpointOOBOperations/Single/PowerCycle/OffSoftGraceful
  • /api/latest/endpointOOBOperations/Single/PowerCycle/OffHardGraceful
  • /api/latest/endpointOOBOperations/Single/PowerCycle/BootToUsbrIso
  • /api/latest/endpointOOBOperations/Single/PowerCycle/BootToUsbrImg
  • /api/latest/endpointOOBOperations/Single/PowerCycle/BootToBios
IB:
  • /api/latest/endpointIBOperations/reboot
  • /api/latest/endpointIBOperations/sleep
  • /api/latest/endpointIBOperations/hibernate
  • /api/latest/endpointIBOperations/alert
  • /api/latest/endpointIBOperations/shutdown
Is there a way to match these commands to group permissions exactly? Some of them seem quite straightforward (like alert and sleep/hibernate), but not sure about the rest.
I would really appreciate some directions here,
Thank you!
vij1
Hello Maksymr,
Greetings!
An endpoint group's policy refers to the IT configurations and rules applied to a specific logical grouping of endpoints within an organization.
These groups—such as those for departments like Accounting or Engineering—enable IT administrators to manage and enforce tailored security, access, and operational policies that align with each group's unique requirements.
By defining these endpoint groups, administrators can apply different configurations, security protocols, and access permissions to endpoints that share common characteristics or roles within the organization.
To clarify, the Sleep policy includes the Hibernate operation as well.
does this matching look correct- yes
Please let me know if you need further details.
Vijay N.
vij1
Hello Maxymr,
Please note that the scripts provided are intended as sample code. These snippets demonstrate various Intel EMA API calls and other related operations. They are primarily designed to serve as examples for your reference and should be customized to fit your own specific use cases.
We recommend using them as part of your own scripts by adding the necessary modifications based on your requirements.
If you have any further questions or need assistance, feel free to reach out.
Vijay N.
maksymr
Hello Vijay,
Yes, I understand this. I was referring to the real values that I receive from the API also:
  "AllowWakeup" : true,
  "AllowSleep" : true,
  "AllowReset" : true,
  "AllowTcpCommunication" : true,
  "AllowAlert" : false,
  "AllowConsole" : true,
  "AllowKvm" : false,
  "AllowFileAccess" : false,
  "AllowWmi" : false,
  "AllowLocation" : true,
  "AllowP2P" : true,
  "AllowUserConsentKVM" : false
This is a payload for this Endpoint Group:
So Im not sure if Sleep would also imply hibernation, and if reset/wakeup would qualify as reboot. Or are some of the commands are just granted by default? That's what I'd like to clarify, because for the IB alert operation, Alert permission must be granted for sure, but it's yet unclear whether it is the case or not for others.
I sure could experiment and switch permissions while trying IB/OOB operations at the same time and see if any error would be thrown, but I was hoping there's a single source of truth that I can rely on here
Thank you
vij1
Hello Maksym,
Greetings!
The full description of all REST API commands, along with their required roles, can be found in the REST API for Intel® Endpoint Management Assistant V5. You can download the complete reference from the link below: Download REST API for Intel® EMA V5
To address your specific questions:
  1. Sleep vs. Hibernate Commands:
2.Reset/Wakeup vs. Reboot:
3.Permission Requirements:
Please refer to the API guide for more details on the roles needed for each operation.
Let me know if you need any further assistance.
Vijay N.
maksymr
Hello Vijay,
The EMA guide is helpful, but still it's a bit unclear on what group policies do I need to have enabled exactly:
And in group policies there are not aligned this way exactly:
So in section 6.4.3, for instance, it states Hibernate along with Sleep, Power off and restart, but there are policies for Sleep, Wakeup, Power off and Restart, but not hibernate. So Sleep policy is going to include Hibernate operation as well, is my assumption correct?
So, for the operations that Im going to use, can you please confirm if this is correct:
OperationGroup PolicyEMA API Response Property
IB: AlertMessaging and alerts: AlertAllowAlert
IB: SleepPower operations: SleepAllowSleep
IB: HibernatePower operations: SleepAllowSleep
IB: RebootPower operations: Turn off or restartAllowReset
IB: ShutdownPower operations: Turn off or restartAllowReset
OOB: Single Sleep LightPower operations: Turn off or restartAllowSleep
OOB: Single Sleep DeepPower operations: Turn off or restartAllowSleep
OOB: Single HibernatePower operations: Turn off or restartAllowSleep
OOB: Single Master Bus ResetPower operations: Turn off or restartAllowReset
OOB: Single Master Bus Reset GracefulPower operations: Turn off or restartAllowReset
OOB: Single Cycle Off SoftPower operations: Turn off or restartAllowReset
OOB: Single Power Off HardPower operations: Turn off or restartAllowReset
OOB: Single Power Cycle Off HardPower operations: Turn off or restartAllowReset
OOB: Single Power Off Soft GracefulPower operations: Turn off or restartAllowReset
OOB: Single Power Off Hard GracefulPower operations: Turn off or restartAllowReset
OOB: Single Power Cycle Off Hard GracefulPower operations: Turn off or restartAllowReset
OOB: Single Power Cycle Off Soft GracefulPower operations: Turn off or restartAllowReset
OOB: Single Power Cycle Boot To USBR ISOPower operations: Turn off or restartAllowReset
OOB: Single Power Cycle Boot To USBR IMGPower operations: Turn off or restartAllowReset
OOB: Single Power Cycle Boot To BIOSPower operations: Turn off or restartAllowReset
So keeping it this explicit, does this matching look correct?
Thank you!
vij1
Hello Maksymr,
Greetings!
Vijay N.
maksymr
Hello Vijay,
This clears it out, thank you!
I have another question about the EMA API, but I'll enter another topic for that, to keep things clean for others who'll face similar issues.
Best regards
vij1
Hello Maksymr,
You're welcome! I'm glad I could help.
Feel free to reach out with any further questions regarding the EMA API. If further assistance is necessary, do not hesitate to reply.
Vijay N.
