Intel vPro® Platform
Intel Manageability Forum for Intel® vPro Fleet Services, EMA, AMT, SCS & Manageability Commander.
3088 Discussions
EMA Server Issues
MikeCh
I am unable to mount an image on any endpoint. Also having issues loading Hardware Manageability on all endpoints.
Thank you in advance for your help.
MikeIntel EMA Hardware Manageability Loading.JPGIntel EMA USBR - Mount Image Error.JPG
PujeethK_Intel
Hello MikeCh,
Greetings!
Thank you for sharing the screenshot. Based on the screenshot, we see that the endpoints are configured in ACM mode, and CIRA is not getting connected.
We would request you to go through the below article and keep us posted.
Intel® Endpoint Management Assistant (Intel® EMA) Issues Getting CIRA Connected – CIRA Not Connected
https://www.intel.com/content/www/us/en/support/articles/000092506/software/manageability-products.html
Additionally would request you to share us the ECT logs from the affected endpoint.
Intel® EMA Configuration Tool (ECT) Logs:
  1. Download the tool from the following link: Intel® EMA Configuration Tool
  2. Installation:
    • Download and unzip the tool.
    • Double-click the .msi file and follow the installation prompts.
  1. Run the Tool:
  2. a. Open a command prompt as an administrator (or use Windows PowerShell*).
  3. b. Navigate to the installation folder (default: C:\Program Files (x86)\Intel\EMAConfigTool).
  4. c. Run the following command:
  5. EMAConfigTool.exe --verbose
Pujeeth_Intel
PujeethK_Intel
Hello MikeCh,
Greetings!
We wanted to follow up on this case to check if you had an opportunity to go through the previous plan of action shared.
Feel free to reply to this email, and we'll be more than happy to assist you further.
Pujeeth_Intel
PujeethK_Intel
Hello MikeCh,
Greetings!
Pujeeth_Intel
