Intel vPro® Platform
3053 Discussions
EMAManageabilityServer application events error
SCCM_MKE_Admin
  I'm getting a ton of the below listed messages on the EMA Platform Manager under EMAManageabilityServer application events.  Has anyone else experienced this? Any assistance is greatly appreciated.
7/3/2020 11:01:53 AM 03 : System.AggregateException: One or more errors occurred. ---> System.Exception: Unable to get database connection, all connections busy.
at MeshServersCommon.DBCore.<ExecuteQuerySafe>d__51.MoveNext()
--- End of inner exception stack trace ---
at System.Threading.Tasks.Task`1.GetResultCore(Boolean waitCompletionNotification)
at MeshManageabilityServer.MeshDatabase.GetNextAction(AmtProvisioningKey& key, IPEndPoint& helloaddr, String& extra, Int32 timeDelayMinutes, AmtProvisioningKeyState rstate, Byte[] nodeidfilter)
at MeshManageabilityServer.CentralManageabilityServer.GetNextAction(Int32 slot, AmtProvisioningKey& key, IPEndPoint& helloaddr, String& extra, Int32 timeDelayMinutes, AmtProvisioningKeyState rstate, Byte[] nodeidfilter)
at MeshManageabilityServer.CentralManageabilityServer.PerformAction()
---> (Inner Exception #0) System.Exception: Unable to get database connection, all connections busy.
at MeshServersCommon.DBCore.<ExecuteQuerySafe>d__51.MoveNext()<---
Emeth_O_Intel
Hello SCCM_MKE_Admin,
Thank you for contacting Intel AMT Communities.
I was reviewing your post and I would like to ask you for some details in order to gather more information.
Have you applied some updates recently?
Have you noticed some performance issues on this system?
Which troubleshooting steps have you performed in order to isolate the issue?
I will be waiting for your outcome in order to proceed with the next step.
Emeth O.
Intel Server Specialist.
MichaelA_Intel
@SCCM_MKE_Admin
Can you check your e-mail? I sent an e-mail to you back on the 10th and don't know if it was received.
Michael
