Intel vPro® Platform
3072 Discussions
Ema 1.14.3.0 setup error
gokhanergul
While installing ema, I get the warning "Intel(R) EMA Platform Manager runtime path not set correctly. Fix it and try again."
Even though I manually saved the necessary paths to the environment variables, the problem was not resolved.
The content of C:\Program Files (x86)\Intel\Platform Manager\Runtime appears empty.
I encounter the same problem despite reinstalling the server many times. How do I solve the problem?
vish1
Hello gokhanergul,
Greetings!!
Could you please let us know if you have followed the steps provided to install Intel® EMA? This will help us understand the current status and assist you more effectively if further support is needed.
Follow these steps to install Intel® EMA:
1.Install Microsoft Server 2019 or 2022
2.Add Server Role: Web Services (IIS)
3.Download and install URL-rewrite
4.Download and install Microsoft SQL Server Enterprise 2017 or higher
5.Download and install SQL Server Management Studio (SSMS)
6.Configure SQL Server:
    • Open SQL Configuration Manager.
  • Go to SQL Server Network Configuration.
  • Open Protocols for SQL Express.
    • Enable: TCP/IP and set IPAII.
  • Go to SQL Server Services.
    • Change the SQL Server Browser state to Automatic and start the service.
7.Open SQL Server Management Studio:
    • On Server name: Type (Server Name\SQL Database Name) if the database is on the same server.
    • For Encryption, select Optional.
  • Select the Security folder.
  • Open the Admin Account of the server.
        • Under Server Roles, assign dbcreator.
  • Under User Mapping, assign Master.
  • Under Database role membership, assign:
            • db_datareader
            • db_writer
    • db_owner
8.Download and install Intel® EMA
Additional Information
Upgrade Intel® EMA Software:
  1. Download the latest Intel® EMA software from Intel® EMA Download Page.
  2. Run the script as an administrator:
EMAServerInstaller FULLINSTALL --updateinstalltype=<single/distributed> --accepteula -c -v
Note: The operating system needs to have English-US Windows display language, English-US system locale, and English-US format (match Windows display language).
Refer section 1.3.2 Operating System for more details-
https://www.intel.com/content/www/us/en/support/articles/000055629.html
Vishal Shet P
intel.com/vpro
vish1
Hello gokhanergul,
Greetings!!
            • db_datareader
            • db_writer
    • db_owner
Vishal Shet P
intel.com/vpro
gokhanergul
I did not apply the database security settings correctly. I followed the instructions one by one and solved the problem thanks to you. I am now testing on the client machine. Thank you for your help.
vish1
Hello gokhanergul,
Greetings!!
We are glad to hear that the issue has been resolved and appreciate your update.
If you need any further assistance in the future, please don’t hesitate to reach out. I will be happy to assist you.
Vishal Shet P
intel.com/vpro
