Intel vPro® Platform
Intel Manageability Forum for Intel® vPro Fleet Services, EMA, AMT, SCS & Manageability Commander.
3092 Discussions
Intel(R) Active Management Technology - SOL com
speedylee
New User
Bonjours j ai toujours mon pilote  Technologie d’administration active Intel(R) - Pilote SOL com 3 ET 4 QUI BUG JE N AI PAS DE GPS et triancle jaunes
Deeksha_S_Intel
Hi David,
Veuillez noter que je ne peux vous soutenir qu’en anglais. J’ai utilisé un outil de traduction Web pour traduire cette réponse, il se peut donc qu’il y ait une traduction inexacte.
We would like to inform you that we are routing your query to the dedicated team for further assistance.
VishalS_Intel
Hello speedylee,
Greetings!!
To proceed further, could you please share the following details of the system:
  • AMT version
  • PC model
Also, we request you to check the ME firmware update from the link below:
https://www.intel.com/content/www/us/en/download/682431/intel-management-engine-drivers-for-windows-10-and-windows-11.html
To help us better understand the environment you are working with and to proceed effectively with the investigation, we kindly request you to provide the SSU and ECT logs.
Intel® EMA Configuration Tool (ECT) Logs:
  1. Download the tool from the following link: Intel® EMA Configuration Tool
  2. Installation:
    • Download and unzip the tool.
    • Double-click the .msi file and follow the installation prompts.
  1. Run the Tool:
  2. a. Open a command prompt as an administrator (or use Windows PowerShell*).
  3. b. Navigate to the installation folder (default: C:\Program Files (x86)\Intel\EMAConfigTool).
  4. c. Run the following command:
  5. EMAConfigTool.exe --verbose
Intel® System Support Utility( SSU):
https://www.intel.com/content/www/us/en/support/articles/000008563/ethernet-products.html
These logs will give us a clearer view of the system configuration and any underlying issues, allowing us to assist you more efficiently.
Please let us know once done or if you need any assistance.
Vishal Shet P
intel.com/vpro
VishalS_Intel
Hello speedylee,
Greetings!!
This is a gentle follow-up regarding our previous email. We are currently awaiting your response to proceed further.
Vishal Shet P
VishalS_Intel
Hello speedylee,
Greetings!!
Vishal Shet P
