Intel vPro® Platform
Intel Manageability Forum for Intel® vPro Fleet Services, EMA, AMT, SCS & Manageability Commander.
3091 Discussions
Enable TLS communication
watamaru2000
Please tell me how to enable TLS communication on a PC equipped with AMT Ver8.0.
(I couldn't find instructions on how to enable TLS communication in the PC manual.)
From a web search, I discovered that it might be possible to achieve this using a tool called MeshCommander, but I was unable to download the tool.
The website for MeshCommander is https://www.meshcommander.com/meshcommander.
By the way, I haven't tried it with other AMT versions either.
MIGUEL_C_Intel
Hello, watamaru2000,
I hope this post finds you well.
Intel AMT 12 started supporting TLS version 1.2 and TLS version 1.0 was removed; TLS comes enabled by default.  A new client type has been created for TLS sessions, which uses a cipher suite with a block size of 256.  The latest remote management tool called Intel® Endpoint Management Assistant (EMA) requires endpoints with AMT version 11.8.79 or higher (the latest version is 16). https://www.intel.com/content/www/us/en/download/19449/intel-endpoint-management-assistant-intel-ema.html
AMT version 8 supports TLS1.1 and it is enabled by default.
Mesh Commander is a third-party open-source tool. I noted the tool was removed; it is not possible to download.
Intel still has Intel® Manageability Commander; this tool will allow remote accessing; however, the latest systems with AMT versions 15, 16, and higher are not compatible.  Please read the software description and guides included in the zip file.
https://www.intel.com/content/www/us/en/download/18796/intel-manageability-commander.html
Miguel C.
MIGUEL_C_Intel
Miguel C.
MIGUEL_C_Intel
I am following up on your post.  If further assistance is necessary, do not hesitate to reply.
Miguel C.
watamaru2000
Hello, Miguel,
Thank you so much for your help.
Your answer was very informative and solved my issue completely.
MIGUEL_C_Intel
You are welcome. Do not hesitate to reply if anything else is necessary.
Miguel C.
