Intel vPro® Platform
Intel Manageability Forum for Intel® vPro Fleet Services, EMA, AMT, SCS & Manageability Commander.
3091 Discussions
Error using Intel AMT Configuration Utility
PF
I'm attempting to use the Intel AMT Configuration Utility and I'm receiving the following error:
"This configuration option is not available because the system does not support host-based configuration."
Hello platinumadmin,
I am sorry for problems you encounter when trying to configure AMT.
Could you please help me with a little more information.
  • OS bee use where you are configuring AMT
  • Hardware installed on the system.
  • AMT .
Thank you for your help and time.
Henry A.
PF
Thank you for the updated information, but could you also please help me with:
• OS bee use where you are configuring AMT – Windows 7 Profession 64-bit
• AMT version has been installed.
Also, might want to double check the AMT configuration manual:
https://www.intel.com/content/dam/support/us/en/documents/software/manageability-products/Intel_AMT_Configuration_Utility.pdf https://www.intel.com/content/dam/support/us/en/documents/software/manageability-products/Intel_AMT_Configuration_Utility.pdf
1.4.1 Host-Based Configuration.
Henry A.
I will like to follow up on your threat and see if you had the opportunity to gather the additional information requested.
But could you also please help me with:
  • AMT .
Henry A.
We haven't heard back from you for several days.
I will close this threat and if you require any additional help you can open a new threat and make reference to this one.
Henry A.
