Intel vPro® Platform
3052 Discussions
Getting "Packet is not encrypted correctly or uses an old key. Last error: 0"
mrant-k
I've gone browsing many posts on this site about this error, but I have not found a single solution that works for us. I have done pulling that cmos out thing someone mentioned in a post, done deprovisioning/re-provisioning/, uninstall/reinstall agent. None is working for me. We are running the latest EMA 1.10.0. Attached is client log file. Please help!
MIGUEL_C_Intel
Hello, Mrant-k,
Thank you for using Intel support services.
I need more details of the configuration before giving you a solution. The version of Intel®'s EMA on the Server is 1.10.0.  Please provide me with more configuration details.
1- Which is the Server operating system, and where is located (physical or virtual machine)?
2- Did you get this error after updating the EMA software version?
3- How many endpoints are provisioned by the EMA server?
4- Please share the current AMT version of the endpoint.
5- Did you configure EMA in Admin Control Mode or Client control mode?
5- Share the EMA installer and EMA Server logs.
EMA logs from Server
[System drive]\Program File(x86)\Intel\Platform Manager\EmaLogs
Installation log:
[System drive]\EMALog-Intel EMAInstaller.txt
Look forward to your response; if there is no response to this email, we will send you a follow-up on 4/25/2023.
Miguel C.
JPxAnderson
I had this issue with some Dell laptops. What I did that resolved the issue was update to the latest BIOS and I installed the latest version of the Intel Management engine components. Once I did that, the laptop immediately provisioned with CIRA active.
mrant-k
Thanks for the tips. In my situation, it appears this issue only happens to relatively older laptops with 7th gen i7. It reports 8th gen and above just fine.
MIGUEL_C_Intel
Hello, Mrant-k,
I hope this post finds you well.
By any chance, have you been able to gather the information requested in my previous response?
Look forward to your response; if there is no response to this email, we will send you a follow-up on 4/28/2023.
Miguel C.
MIGUEL_C_Intel
Hello, mrant-k,
Intel® EMA requires endpoint machines with Intel® Active Management Technology (AMT) version 11.8.79 or newer.  Details on section 5 - Agent Prerequisites.
https://downloadmirror.intel.com/646990/Intel_EMA_Release_Notes.pdf#page=16
Intel® EMA Configuration Tool helps us to gather the AMT version of the machine.
https://www.intel.com/content/www/us/en/download/19805/30485/intel-endpoint-management-assistant-configuration-tool-intel-ema-configuration-tool.html
Installation:
Double-click the .msi file and follow the prompts.
Run:
a- Open a command prompt (alternatively, you can run the tool from within Windows PowerShell*).
b- Navigate to the installation folder (default C:\Program Files (x86)\Intel\EMAConfigTool).
c- Run the command: EMAConfigTool.exe -filename XXXX --verbose
If assistance is necessary, please answer the question below.
Path for EMA logs from Server:
Installation log:
Look forward to your response; if there is no response to this email, we will send you a follow-up on 5/2/2023.
Miguel C.
MIGUEL_C_Intel
Hello, mrant-k,
I am following up on the case and wondering if further assistance is necessary.
Look forward to your response; if there is no response to this email, we will send you a follow-up on 5/5/2023.
Miguel C.
MIGUEL_C_Intel
Hello, mrant-k,
If further assistance is necessary, do not hesitate to reply.
Miguel C.
mrant-k
The issue hasn't resolved. I'm still getting the same error. And Platform Manager shows "01:Failed PKI provoisioning: BB270779"
