Intel vPro® Platform
Intel Manageability Forum for Intel® vPro Fleet Services, EMA, AMT, SCS & Manageability Commander.
3084 Discussions
Help Required in Installing the AMT Set up and Configuration Service
I am facing difficulty in setting up Intel Setup and Configuration Service (v5.1.0.50) on our server.
The server specifications are:
Windows 2003 Standard Edition (64-bit) SP2
Internet Information Services 6.0
.NET Framework 2.0 SP2
MS SQL Server 2005
Installation steps taken so far:
I installed both AMTConfServer and AMTConsole on my server. Prior to the installation of the AMTConfServer I have installed the Active Directory and the Certification Authority. Also I have enabled the secure TLS\SSL connection with the SCS Server.But the problem is that when I am trying to connect to the Setup and Configuration Service through the AMT Console with the following default url
http://localhost/amtscs https://localhost/amtscs
http://testserver/amtscs https://testserver/amtscs
http://testserver.ad.domain.edu/amtscs https://testserver.domain/amtscs
I am getting the following error.
Unable to connect to {server} (Reason: Response is not well-formed XML)
If I navigate to the site using my Administrator login or the AD Service account (http://localhost/amtscs https://localhost/amtscs, or http://testserver.domain.edu/amtscs https://testserver.domain.edu/amtscs) I get a 403 Forbidden error.
Any thoughts to resolve this?
Sai
