Intel vPro® Platform
3053 Discussions
Help with 802.1X certificate template
GRile
Hi all,
We are using 802.1X to secure our wired network and our Windows 10 machines are using PEAP (Computer Authentication) as specified using Group Policy. This all works great but I now need to try and figure out how to get 802.1X working for AMT. The only guide I can find regarding how to configure the template is https://technet.microsoft.com/en-us/library/gg682023.aspx# BKMK_AMT2008_cm2012 this one specifically the section "Creating and Issuing the Client Authentication Certificates for 802.1X AMT-Based Computers". Does this still apply given that our build of SCCM (1610) no longer supports OOB? The problem is that when building a profile on a test machine, in the part where I specify the special 802.1X certificate, it doesn't appear within the drop down box. I can only select my "AMTClientConfigurationcertificate" certificate.
I have another question:
I've mostly been using https://sccmguru.wordpress.com/2013/12/22/integrating-configuration-manager-2012-r2-with-intel-scs-9-0-part-3-certification-authority/ this guide for setting it all up but I wondered if the "Web certificate" part is still required given we are using SCCM 1610?
Many thanks in advance,
Graham
GRile
Never mind, I didn't need to bother with a certificate in the end, I just needed to import the RootCA cert.
