Intel vPro® Platform
Intel Manageability Forum for Intel® vPro Fleet Services, EMA, AMT, SCS & Manageability Commander.
3088 Discussions
How To Resolve Unable to successfully validate Azure AD settings
HoldenJolley
I managed to get Intel EMA Installed, but I can't get it to sync with the Azure App that I made before. The fqdn in the web uri and the put request match, I am not sure why it is failing. Any help would be appreciated
Arun_Intel1
Hi HoldenJolly,
Greetings!
Please check the Azure API Permissions and make sure that Delegated and Application Permissions were selected correctly and granted, you may have incorrectly added User.Read.All with type Delegated instead of Application. kindly make a change to the type back to Application, we will be able to save the settings successfully and continue with our setup.
Please find the attached screenshot.
Best Regards
Arun_Intel
HoldenJolley
Hi Arun,
In the body of the post, I have attached screenshots of the app, in the screenshots to my knowledge the permissions have been assigned correctly.
Jimmy_Wai_Intel
Hi HoldenJolley,
Please see if the following would help. These are required for Entra ID integration to work.
1. Check if your Intel EMA server is able to access the following URLs directly, without going thru a proxy server.
2. Your Intel EMA web server needs to have a valid web server certificate installed in IIS on port 443
3. The Redirect URI in your screenshot is accessible by Microsoft Identity platform
https://graph.microsoft.com
https://login.microsoftonline.com
Jimmy Wai
Technical Sales Specialist, Intel
Arun_Intel1
Hi HoldenJolly,
Greetings!
Please confirm if you were able to execute the plan of action given above, if yes, kindly share your observation.
Best Regards
Arun_intel
Arun_Intel1
Hi HoldenJolley,
Greetings!
Please feel free to reply for any further query!
Thank you for contacting Intel!
Best Regards
Arun_Intel
