Intel vPro® Platform
3006 Discussions
How to apply for a AMT provisioning of an external CA?
Hi, I created a provisioning certificate from a CA of my organization. I added the HASH of a computer and this has provisioning correctly, with or without client.
I requested a certificate to an external CA (Verisign), to create the certificate with ISS 7.0 on the Common Name must be put provisioning server or is not needed?
According to "http://technet.microsoft.com/en-us/library/cc161874.aspx http://technet.microsoft.com/en-us/library/cc161874.aspx" if used to request the certificate "Intel (R) Client Setup Certificate", CN would have to put the FQDN of the provisioning server, not?
Certificates of provisioning created from an internal CA is not needed as we add in 2.16.840.1.113741.1.2.3 generated template, isn't it?
of an external AC supply?
Sorry for my English, thanks
Jacob_G_Intel
This walk through should help. /docs/DOC-2200 http://communities.intel.com/docs/DOC-2200
Basically, you have it right...when requesting a certificate from verisign you must use an organizational unit of "Intel(R) Client Setup Certificate" (no quotes) and use the FQDN of your provisioning server as the CN on the certificate. Hope this helps, and good luck!
Jacob_G_Intel
