Intel vPro® Platform
3052 Discussions
How to use One Click Recovery (OCR) on Intel EMA?
RyomaFujiki
Hello.
I can't find any documents describing the specific usage and procedure of One Click Recovery (OCR) in Intel EMA.
If you have it, please share it with us.
If not, it would be helpful if you could explain the specific procedure on the EMA WebUI with screenshots.
Or a video of using OCR on EMA would be fine.
We are especially interested in knowing if it is possible to run Win RE OCR on multiple PCs at once in EMA.
Best regards.
JoseH_Intel
Hello RyomaFujiki,
Thank you for joining the Intel community
The high level info about the One Click Recovery (OCR) feature could be found here: https://www.intel.com/content/dam/support/us/en/documents/software/manageability-products/intel-ema-admin-and-usage-guide.pdf#page=15
For more in depth explanation and usage info go here: Intel® AMT SDK Implementation and Reference Guide
Jose A.
RyomaFujiki
Hello Jose A,
Thank you for your response.
I have already looked at the documents you shared.
However, it is difficult to understand because there are no specific procedures described.
Also, there does not appear to be any description of the procedure on the EMA WebUI.
Is there a more specific document?
Besides ACM provisioning in EMA 1.7.1, is there any other preparation needed to use WinRE's OCR?
Where in the EMA WebUI can I use the OCR feature?
Can OCR from the EMA WebUI be used on multiple PCs at once?
Best regards.
JoseH_Intel
Hello RyomaFujiki,
Well this is kind of a new feature only available on 12th gen Intel core processors on systems with a supported BIOS and HDD. To be honest I am aware about this feature but have not seen it working yet. Let me try to get some more info related to this.
Jose A.
JoseH_Intel
Hello RyomaFujiki,
We are looking for an internal demo that we may share with you. Since your company have NDAs in place with us we are sure it won't be a problem if we have one.
At a deeper level here is how One-Click Recovery works at an AMT level....
Jose A.
RyomaFujiki
Hello Jose A,
Thank you for your continued support.
We look forward to your response.
JoseH_Intel
Hello RyomaFujiki,
We are still working on finding the promised demo. I will let you know as soon as we have updates.
Jose A.
RyomaFujiki
Hello Jose A,
Additional information.
I have an AMT v16 PC to check and cannot find the OCR function.
I thought it might be available through "PowerCommand" but it is not. (Fig1)
I have checked "One Click Recovery" in AMT Profile settings. (Fig2)
We have confirmed that the OCR function can be used with Mesh Commander.
We are waiting for your information.
SergioS_Intel
Hello RyomaFujiki,,
Thank you for waiting for our updates.
After further investigation apart from the technical details we shared, we don't have a demo OneClick Recovery available at the moment.
 We do apologize for the confusion.
 Sergio S.
RyomaFujiki
Hello Jose A,
I understand that there is no demo.
Can you give us the steps to actually use OCR in EMA?
Currently, we cannot find the OCR function.
Current Status
・ACM provisioning is available on AMT v16 OCR-enabled PCs.
・We have confirmed that the OCR function can be used with Mesh Commander.
・Recovery Server is running. (Fig3)
Best regards.
RyomaFujiki
Hello Sergio S,
Do you have an answer yet?
We are waiting for your response.
Best regards.
T_K_1
Hello Intel-san,
I am Kojima. And I took over this item from Fujiki-san,
Please let me know if there is any update.
Teruki Kojima.
