Intel vPro® Platform
Avisos
3051 Discusiones
I7 920 TDP of 147.5 - just how bad is this?
Empleados
1.521 Vistas
Just built a new I7 920, and it appears to be running well, except for the aforementioned TDP of 147.5 watts. It is seated in a Gigabyte GA-EX58-UD3R moBo and the AWARDbios seems to be alarmed by this (since an earlier build of a similar machine of same CPU and MoBo o'clocked to 3.00GHz is running with a TDP of 130 watts, it worries me as well) . It emits two long beeps and then backs off for about 13 seconds, before repeating. As far as I can recall, this didn't occur until after I had installed W7 Home Premium 64 bit. Have been unable to find anything at Gigabyte about the beeps I am hearing, nor elsewhere on the web, but if the I7 is the cause, or faulty.......
Any and all help greatly appreciated.
1 Responder
Empleados
646 Vistas
This sounds like a PSU problem (if its a cheap one) not only that but you need an 8 pin CPU connector if your not already using one.
Responder
