Intel vPro® Platform
3052 Discussions
Intel AMT Diagnostics Tool documentation
SRoch4
Where can I find documentation for the AMT Diagnostics Tool? It comes with a help file but that seems geared towards writing diagnostic code rather than using the GUI program.
In particular, there's a set of tests and I don't know what's supposed to go in the "active directory" section - the on screen help says it needs an OU for the machine object and a CN but when I enter values which I'm sure are correct (I can see them in AD Users and Computers) it fails the test. It would be good to have an example of the format which is expected.
Also, what should I give for the server certificate - if I point it at the text file I downloaded from Entrust the test is passed but when I try to provision machines I'm getting warnings about certificate errors.
Steve
