Intel vPro® Platform
Intel Manageability Forum for Intel® vPro Fleet Services, EMA, AMT, SCS & Manageability Commander.
3089 Discussions
Intel AMT Support Identification
Endrianus
I have CPU with intel Core i7-10700 which support intel VPro.
But I can't identify whether it support AMT or not because the AMT port is not listed in the device manager.
Also when I download the Intel Management and Security Status it says that the service status information unavailable.
How can I know for sure that my hardware support it ?
Thanks before.
AlHill
What motherboard?   What chipset?
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
Endrianus
Hi Alhill,
Thanks for responding and sorry for late reply.
Attached is what you requested.
peter3499
well actually AMT is defined by your chipset or motherboard. So can you tell us which chip-set are you using
Endrianus
Hi Peter,
I'm using
Intel(R) Core(TM) i7-10700 CPU @ 2.90GHz
as my chipset .
n_scott_pearson
Al is correct. In order to have a vPro-ready system, you must have a vPro-ready processor AND a vPro-ready chipset. Only the Q chipsets are vPro-ready. Your system has a H chipset. This means that it is not vPro-ready and you consequently cannot use AMT.
Sorry,
Endrianus
Hi Scott,
How can you the chipset type ? Because I don't see one.
n_scott_pearson
Well, you would expect Acer to detail this in their specs, but noooo, that would be the right thing to do, not the Acer thing (can you tell I am not a fan?). I ended up looking at the specs detailed in various reviews. I finally found one (though I cannot remember where now) that said the chipset was H470.
You should be able to look this up by going into BIOS Setup.
Endrianus
Hi n_scott_pearson,
I don't see one in my BIOS.
JoseH_Intel
Hello peter3499,
Thank you for joining the Intel community
For a system to be AMT capable it requires 3 AMT capable components. Processor, Chipset and Intel NIC.  If you have further questions just let me know.
Hope this helps
Jose A.
Endrianus
Hi JoseH_Intel,
Where can I make sure that my system is AMT Capabled ?
Because I can't find it somewhere in BIOS or Device Manager.
n_scott_pearson
Do you have a vPro-enabled processor combined with a vPro-enabled chipset? Only this combination - which requires a Q chipset (and NOT a Z, H or B chipset) - will support AMT.
