Intel vPro® Platform
3052 Discussions
Intel AMT reconfigure fails
SysArch
​The Configuration of an uncofigured device works fine. But if I execute the same command to reconfigure the device, the command Fails:
"Exit with code 75. Details: Failed to complete remote configuration of this Intel(R) AMT device. Final status of Intel(R) AMT is unknown because a failure occurred when configuring the system. Intel(R) AMT operation failed. Error while configuring TLS settings. A TCP error occurred. Make sure that the destination settings are correct and that a network connection exists to the target. ".
I used the following command:
ACUConfig.exe /output console ConfigViaRCSonly amt1.example.com DefaultProfile
After the device is set to unconfigured, the configuration (with the above command) works fine again.
ACUConfig.exe /output console unconfigure
I added the verbose log of a successfully configuration and a failed reconfiguration as attachment.
Does anybody know why the reconfiguration fails?
Best regards, fabian
SysArch
I was able to implement a workaround by allow the TCP port 16992 from RCS-Server to Client although TLS is used. I think this is a Bug, because the implementation guide advise, that port 16992 is not used if TLS is enabled ("Starting with Release 6.0, the port is optionally open when TLS is enabled") https://software.intel.com/sites/manageability/AMT_Implementation_and_Reference_Guide/default.htm?turl=WordDocuments%2Fmanageabilityports.htm
To clarify:
To configure a unconfigured device over RCS the following ports are sufficiently:
RPC (135,49152-65335)
AMT HTTPS (16993)
To reconfigure a already configured device over RCS the following ports are required:
AMT HTTPS (16993)
AMT HTTP (16992)
Can you confirm the incorrect behavior of Intel RCS v12.1.0 with Intel AMT 11.8.65?
Best regards
JoseH_Intel
Hello SysArch,
Thank you for joining the community
May I ask if this device you unconfigured and tried to reconfigure was already provisioned and functional before the unconfiguration?
The reason for failure looks like a TLS compatibility and/or configuration issue. Did you enabled TLS on the xml profile for the reconfiguration?
Jose A.
A Contingent Worker at Intel
SysArch
Hi Jose
Yes, the same device was already provisioned with the same Profile on RCS.
What I did exactly:
  1. Configure Client1 by ACUConfig.exe via RCS-Server Amt1 with DefaultProfile --> Successful
  2. Configure Client1 by ACUConfig.exe via RCS-Server Amt1 with DefaultProfile --> Failed
  3. Unconfigure Client1 by ACUConfig.exe --> Successful
  4. Configure Client1 by ACUConfig.exe via RCS-Server Amt1 with DefaultProfile --> Successful
  5. Configure Client1 by ACUConfig.exe via RCS-Server Amt1 with DefaultProfile --> Failed
I used the same rcs, client and profile in all steps. From the RCS-Server I can connect the AMT webinterface on Client1 over HTTPS without any certificate warnings.
As additional information I added the RCS Log for a successful configuration and a failed reconfiguration as attachment. Maybe it helps for your troubleshooting.
SysArch
Was not possible to add two files in the same post, so here is the second one
SysArch
To clarify:
AMT HTTPS (16993)
AMT HTTPS (16993)
AMT HTTP (16992)
Best regards
JoseH_Intel
Hello SysArch,
Its good to hear you figured out this workaround and got it fixed.
It is possible the ports issue might be a bug, but it is known that both ports 16992 and 16993 are used depending a TLS or non TLS connection. What changes between AMT v11 to v12 is the deprecation of TLS 1.0 for security purposes mainly.
Jose A.
SysArch
"it is known that both ports 16992 and 16993 are used depending a TLS or non TLS"
Right 16992 for non TLS and 16993 for TLS. It is explicit documented (https://software.intel.com/sites/manageability/AMT_Implementation_and_Reference_Guide/default.htm?turl=WordDocuments%2Fmanageabilityports.htm), that port 16992 is not required if TLS is used. But based on my experience 16992 is also required during reconfiguration although using TLS.
Best regards
