Intel vPro® Platform
Intel Manageability Forum for Intel® vPro Fleet Services, EMA, AMT, SCS & Manageability Commander.
3084 Discussions
Intel EMA Installation Error- Error when Creating Intel® EMA Root Cert
HoldenJolley
Hello, I am working through the Intel EMA installation process, but I hit a snag, I have the logs to send but I am not sure where I am stuck at, also I am not sure if I will need to restart the entire installation process or if it will kick off from where it is currently stopped, any and all help is appreciated.
Arun_Intel1
Hello HoldenJolley,
Greetings!
Thanks for confirm,
Yes, we see that this should be the one that is causing the issue, please refer to the screen shot attached, which shows the certificate options that is reflecting in the settings tab of the EMA console, and that is how it should be seen once the certificates are provisioned.
Please find the section 3.5 on the Admin and Usage guide shared below:
https://www.intel.com/content/dam/support/us/en/documents/software/manageability-products/intel-ema-admin-and-usage-guide.pdf
Best Regards
Arun_Intel
Arun_Intel1
Hi HoldenJolley,
Greetings!
We see that you are getting an error while installin the EMA Root Cert, please share the screen shot of the error that you are getting.
Best Regards
Arun_Intel
HoldenJolley
Arun_Intel1
Hi HoldenJolley,
Thanks for sharing the picture.
Please find the link give below for the article, which speaks about the purchase and configuration of the Root, Intermittent and the PKI certificate.
https://www.intel.com/content/www/us/en/support/articles/000020785.html
Please follow the article steps to configure the Root certificate to make sure that we are not missing any steps and share your observation.
Best Regards
Arun_Intel
HoldenJolley
I do have the cert, I don't believe that the cert is installed yet. But I got this error during the initial installation of EMA, is it typical to install the cert before launching the EMA Installer?
Arun_Intel1
HoldenJolley,
Right, we see that you have the GoDaddy certificate purchased already. If you are provisioning the EMA in the ACM mode, yes, you may have to install the certificate as shown in the link shared.
And sure, you may continue from the place where you have stopped the EMA installation.
Please find the EMA installation guide given below for reference.
https://downloadmirror.intel.com/646990/Intel_EMA_Documentation_Rev1.14.0.zip
Best Regards
Arun_Intel
HoldenJolley
I did the above but now I am getting a different error before I can even finish the installation
Arun_Intel1
HoldenJolley,
Greetings!
Thanks for sharing your observation.
The issue seems to be with the communication between the EMA server and the EMA database.
  • Which operating system will handle the Intel® EMA server?
  • Will the EMA server and EMA database in the same machine? (Physical or virtual)
  • Did you let Intel® EMA software create the EMA database, or you are using an existing one?
  • Which is the SQL version of the EMA database, and the OS of the machine?
  • Is the EMA database admin the same as the SQL database? (db owner)
  • Will you authenticate the endpoints with EMA, Windows AD, or Azure AD?
  • Did you log into Windows Server with the Admin User of the Active Directory?
  • Is the EMA installer the same Admin User of the Active Directory?
  • Does the Admin User of the Active Directory have access to the SQL database?
  • Please remember to run EMA software with Administrator rights.
For reference, review section 1.3.3 Database of the Intel(R) EMA Server Installation and Maintenance Guide.pdf version 1.11.0 (latest) included in the EMA software zip file.
https://www.intel.com/content/www/us/en/download/19449/intel-endpoint-management-assistant-intel-ema.html
Best Regards
Arun_Intel
HoldenJolley
  1.  Windows Server 2022
  2.  Ema Server and the EMA Databse are two seperate servers, they are both virtual
  3. The EMA installer created the database and the first time it ran fine, later giving the error we talked about above, I only started getting this new error after installing the certs
  4. Microsoft SQL 2019 and Windows Server 2022
  5. Yes, they should be the same
  6. Azure AD
  7. Yes
  8. Yes
  9. I can confirm that it is running with admin rights
HoldenJolley
Also, in case you need the log here is what the error is in the log file
2024-10-17 14:00:24.5647|ERROR||6060|1|DisplayEvent - MeshServerInstaller.MainForm, EMAServerInstaller, Version=1.13.1.0, Culture=neutral, PublicKeyToken=57d11e903ea1ca2c - EVENT: Exception, Missing, invalid or multiple MeshSettingsCertificates found in cert store. Add or replace certificate in cert store from backup.
Arun_Intel1
Hi Holden Jolley,
Thanks for sharing that information.
We would recommend uninstalling the Intel EMA server, if it is a first installation. (screen shots have been attached)
Then navigate to the certificates on the local machine, as shown in screen shot and delete all the certificates under the personal tab in the local Computer.
And reinstall EMA from the scratch and then provision the certificates once the Intel EMA server installation is successfully completed.
Please execute the plan of action shared above and share your observation.
Best Regards
Arun_Intel
HoldenJolley
I tried that with no success, I did notice that my certs are a little different than what the pdf says, could this be part of the issue?
Arun_Intel1
Hello HoldenJolley,
Greetings!
Thanks for confirm,
Best Regards
Arun_Intel
HoldenJolley
I have removed the old certs and got the new go daddy certs in, but I am still getting the same error message
Below is the log file for the error message
2024-10-22 09:11:23.4397|INFO||7740|1|DisplayEvent - MeshServerInstaller.MainForm, EMAServerInstaller, Version=1.13.1.0, Culture=neutral, PublicKeyToken=57d11e903ea1ca2c - EVENT: Information, Found site: Default Web Site
2024-10-22 09:11:23.5022|INFO||7740|1|DisplayEvent - MeshServerInstaller.MainForm, EMAServerInstaller, Version=1.13.1.0, Culture=neutral, PublicKeyToken=57d11e903ea1ca2c - EVENT: Information, Ready to get started. Select an option above.
2024-10-22 09:11:25.7368|INFO||7740|1|DisplayEvent - MeshServerInstaller.MainForm, EMAServerInstaller, Version=1.13.1.0, Culture=neutral, PublicKeyToken=57d11e903ea1ca2c - EVENT: Information, Start checking installer readiness.
2024-10-22 09:11:25.7368|INFO||7740|1|DisplayEvent - MeshServerInstaller.MainForm, EMAServerInstaller, Version=1.13.1.0, Culture=neutral, PublicKeyToken=57d11e903ea1ca2c - EVENT: Information, Start checking packages.
2024-10-22 09:11:25.7835|INFO||7740|1|DisplayEvent - MeshServerInstaller.MainForm, EMAServerInstaller, Version=1.13.1.0, Culture=neutral, PublicKeyToken=57d11e903ea1ca2c - EVENT: Information, Start checking package: EMAAjaxServer.
2024-10-22 09:11:25.8929|INFO||7740|1|DisplayEvent - MeshServerInstaller.MainForm, EMAServerInstaller, Version=1.13.1.0, Culture=neutral, PublicKeyToken=57d11e903ea1ca2c - EVENT: Information, Package signature verified successfully: C:\Users\hjolley\AppData\Local\Temp\StoredPackages\EMAAjaxServer.zip
2024-10-22 09:11:25.8929|INFO||7740|1|DisplayEvent - MeshServerInstaller.MainForm, EMAServerInstaller, Version=1.13.1.0, Culture=neutral, PublicKeyToken=57d11e903ea1ca2c - EVENT: Information, Package version verified successfully: C:\Users\hjolley\AppData\Local\Temp\StoredPackages\EMAAjaxServer.zip
2024-10-22 09:11:25.9085|INFO||7740|1|DisplayEvent - MeshServerInstaller.MainForm, EMAServerInstaller, Version=1.13.1.0, Culture=neutral, PublicKeyToken=57d11e903ea1ca2c - EVENT: Information, Package name verified successfully: C:\Users\hjolley\AppData\Local\Temp\StoredPackages\EMAAjaxServer.zip
2024-10-22 09:11:25.9085|INFO||7740|1|DisplayEvent - MeshServerInstaller.MainForm, EMAServerInstaller, Version=1.13.1.0, Culture=neutral, PublicKeyToken=57d11e903ea1ca2c - EVENT: Information, Start checking package: EMAManageabilityServer.
2024-10-22 09:11:25.9872|INFO||7740|1|DisplayEvent - MeshServerInstaller.MainForm, EMAServerInstaller, Version=1.13.1.0, Culture=neutral, PublicKeyToken=57d11e903ea1ca2c - EVENT: Information, Package signature verified successfully: C:\Users\hjolley\AppData\Local\Temp\StoredPackages\EMAManageabilityServer.zip
2024-10-22 09:11:25.9872|INFO||7740|1|DisplayEvent - MeshServerInstaller.MainForm, EMAServerInstaller, Version=1.13.1.0, Culture=neutral, PublicKeyToken=57d11e903ea1ca2c - EVENT: Information, Package version verified successfully: C:\Users\hjolley\AppData\Local\Temp\StoredPackages\EMAManageabilityServer.zip
2024-10-22 09:11:26.0023|INFO||7740|1|DisplayEvent - MeshServerInstaller.MainForm, EMAServerInstaller, Version=1.13.1.0, Culture=neutral, PublicKeyToken=57d11e903ea1ca2c - EVENT: Information, Package name verified successfully: C:\Users\hjolley\AppData\Local\Temp\StoredPackages\EMAManageabilityServer.zip
2024-10-22 09:11:26.0023|INFO||7740|1|DisplayEvent - MeshServerInstaller.MainForm, EMAServerInstaller, Version=1.13.1.0, Culture=neutral, PublicKeyToken=57d11e903ea1ca2c - EVENT: Information, Start checking package: EMASiteCoreReact.
2024-10-22 09:11:26.8929|INFO||7740|1|DisplayEvent - MeshServerInstaller.MainForm, EMAServerInstaller, Version=1.13.1.0, Culture=neutral, PublicKeyToken=57d11e903ea1ca2c - EVENT: Information, Package signature verified successfully: C:\Users\hjolley\AppData\Local\Temp\StoredPackages\EMASiteCoreReact.zip
2024-10-22 09:11:26.8929|INFO||7740|1|DisplayEvent - MeshServerInstaller.MainForm, EMAServerInstaller, Version=1.13.1.0, Culture=neutral, PublicKeyToken=57d11e903ea1ca2c - EVENT: Information, Package version verified successfully: C:\Users\hjolley\AppData\Local\Temp\StoredPackages\EMASiteCoreReact.zip
2024-10-22 09:11:26.8929|INFO||7740|1|DisplayEvent - MeshServerInstaller.MainForm, EMAServerInstaller, Version=1.13.1.0, Culture=neutral, PublicKeyToken=57d11e903ea1ca2c - EVENT: Information, Package name verified successfully: C:\Users\hjolley\AppData\Local\Temp\StoredPackages\EMASiteCoreReact.zip
2024-10-22 09:11:26.9085|INFO||7740|1|DisplayEvent - MeshServerInstaller.MainForm, EMAServerInstaller, Version=1.13.1.0, Culture=neutral, PublicKeyToken=57d11e903ea1ca2c - EVENT: Information, Start checking package: EMASwarmServer.
2024-10-22 09:11:26.9710|INFO||7740|1|DisplayEvent - MeshServerInstaller.MainForm, EMAServerInstaller, Version=1.13.1.0, Culture=neutral, PublicKeyToken=57d11e903ea1ca2c - EVENT: Information, Package signature verified successfully: C:\Users\hjolley\AppData\Local\Temp\StoredPackages\EMASwarmServer.zip
2024-10-22 09:11:26.9710|INFO||7740|1|DisplayEvent - MeshServerInstaller.MainForm, EMAServerInstaller, Version=1.13.1.0, Culture=neutral, PublicKeyToken=57d11e903ea1ca2c - EVENT: Information, Package version verified successfully: C:\Users\hjolley\AppData\Local\Temp\StoredPackages\EMASwarmServer.zip
2024-10-22 09:11:26.9866|INFO||7740|1|DisplayEvent - MeshServerInstaller.MainForm, EMAServerInstaller, Version=1.13.1.0, Culture=neutral, PublicKeyToken=57d11e903ea1ca2c - EVENT: Information, Package name verified successfully: C:\Users\hjolley\AppData\Local\Temp\StoredPackages\EMASwarmServer.zip
2024-10-22 09:11:26.9866|INFO||7740|1|DisplayEvent - MeshServerInstaller.MainForm, EMAServerInstaller, Version=1.13.1.0, Culture=neutral, PublicKeyToken=57d11e903ea1ca2c - EVENT: Information, Start checking package: EMARecoveryServer.
2024-10-22 09:11:27.0335|INFO||7740|1|DisplayEvent - MeshServerInstaller.MainForm, EMAServerInstaller, Version=1.13.1.0, Culture=neutral, PublicKeyToken=57d11e903ea1ca2c - EVENT: Information, Package signature verified successfully: C:\Users\hjolley\AppData\Local\Temp\StoredPackages\EMARecoveryServer.zip
2024-10-22 09:11:27.0491|INFO||7740|1|DisplayEvent - MeshServerInstaller.MainForm, EMAServerInstaller, Version=1.13.1.0, Culture=neutral, PublicKeyToken=57d11e903ea1ca2c - EVENT: Information, Package version verified successfully: C:\Users\hjolley\AppData\Local\Temp\StoredPackages\EMARecoveryServer.zip
2024-10-22 09:11:27.0491|INFO||7740|1|DisplayEvent - MeshServerInstaller.MainForm, EMAServerInstaller, Version=1.13.1.0, Culture=neutral, PublicKeyToken=57d11e903ea1ca2c - EVENT: Information, Package name verified successfully: C:\Users\hjolley\AppData\Local\Temp\StoredPackages\EMARecoveryServer.zip
2024-10-22 09:11:27.0647|INFO||7740|1|DisplayEvent - MeshServerInstaller.MainForm, EMAServerInstaller, Version=1.13.1.0, Culture=neutral, PublicKeyToken=57d11e903ea1ca2c - EVENT: Information, A copy of all required packages already present.
2024-10-22 09:11:27.0647|INFO||7740|1|DisplayEvent - MeshServerInstaller.MainForm, EMAServerInstaller, Version=1.13.1.0, Culture=neutral, PublicKeyToken=57d11e903ea1ca2c - EVENT: Information, Finish checking packages.
2024-10-22 09:11:27.0647|INFO||7740|1|DisplayEvent - MeshServerInstaller.MainForm, EMAServerInstaller, Version=1.13.1.0, Culture=neutral, PublicKeyToken=57d11e903ea1ca2c - EVENT: Information, Finish checking installer readiness.
2024-10-22 09:11:27.0804|INFO||7740|1|DisplayEvent - MeshServerInstaller.MainForm, EMAServerInstaller, Version=1.13.1.0, Culture=neutral, PublicKeyToken=57d11e903ea1ca2c - EVENT: Information, Ready.
2024-10-22 09:12:04.8772|INFO||7740|1|DisplayEvent - MeshServerInstaller.MainForm, EMAServerInstaller, Version=1.13.1.0, Culture=neutral, PublicKeyToken=57d11e903ea1ca2c - EVENT: Information, Existing Intel® EMA version detected. Update installation will be performed.
2024-10-22 09:12:04.8934|INFO||7740|1|DisplayEvent - MeshServerInstaller.MainForm, EMAServerInstaller, Version=1.13.1.0, Culture=neutral, PublicKeyToken=57d11e903ea1ca2c - EVENT: Information, Your IIS web.config file will be renamed to web.config.orig.<date> and a new web.config file installed. IIS bindings will be set to default values.
2024-10-22 09:12:04.9397|ERROR||7740|1|DisplayEvent - MeshServerInstaller.MainForm, EMAServerInstaller, Version=1.13.1.0, Culture=neutral, PublicKeyToken=57d11e903ea1ca2c - EVENT: Exception, Missing, invalid or multiple MeshSettingsCertificates found in cert store. Add or replace certificate in cert store from backup.
Arun_Intel1
Hi HoldenJolley,
Greetings!
This is the first Follow up, please let us know if you were able to execute the plan of action shared, if yes, kindly share your observation.
Best Regards
Arun_Intel
HoldenJolley
Hi Arun,
I did manage to get past that part, so thank you for the assistance there, I made some progress before getting stuck again. So, if you are up for it How To Resolve Unable to successfully validate Azure AD settings - Intel Community is the new issue that I am having; but overall, I just wanted to say thank you for assisting me through the installation process.
Arun_Intel1
Hi HoldenJolley,
Sure, thanks for confirming.
We shall continue the new issue on the different community thread raised.
Arun_Intel
Arun_Intel1
Hi HoldenJolley,
Greetings!
Please feel free to reply for any further query!
Best Regards
Arun_Intel
