Intel vPro® Platform
3077 Discussions
Intel RCS creates a computer object with the same attributes as the corresponding windows computer object
SysArch
Hi
I use Intel RCS 12.1.0 to configure Intel AMT devices. All devices are Windows domain members and AMT Active Directory integrated. The Active Directory computer objects created by Intel RCS, have the same CN and Name attributes as the windows computer object . So, if I search for the computername "client1" in active directory I get two computerobjects (the amt and windows object), altough SamAccountName and distinguished name is unique.
The problem ist, that some applications (like Microsoft LAPS UI) no longer work because they can no longer uniquely identify the windows computer object by name.
Does Intel have a solution for this problem? Can the RCS create the computer object with a different CN than the Windows computerobject?
Best regards, fabian
SergioS_Intel
Hello Sysarch,
Please help us provide with some information about your system configuration:
How many systems configure with AMT you have?
Can you please provide us with the manufacturer of your systems?
What operating system are you currently running?
Sergio S.
SysArch
Hi Sergio
How many systems configure with AMT you have? About 15'000
Can you please provide us with the manufacturer of your systems? Flytech
What operating system are you currently running? Windows 10
SergioS_Intel
Hello Sysarch,
We appreciate the additional information, allow us to check with upper-level support and we will get back to you.
Sergio S.
SergioS_Intel
Hello Sys Arch,
Using the LAPS tool, when you search for an object, you have to use the full LDAP address and the unique object will show. Alternatively, you can use a PowerShell command. The first command “Get’s” the password from the object and the second command “Reset’s” the password:
Get LAPS Password (when you also have AMT computer objects):
[CmdletBinding()]
Param([Parameter(Mandatory =$true, position=0, HelpMessage="Enter the Computer Name")][String]$ComputerName)
$RealComputer = Get-ADComputer -Identity $ComputerName
Get-AdmPwdPassword -ComputerName $RealComputer
Reset LAPS Password (when you also have AMT computer objects):
[CmdletBinding()]
Param([Parameter(Mandatory =$true, position=0, HelpMessage="Enter the Computer Name")][String]$ComputerName,
[Parameter(Mandatory =$true, position=1, HelpMessage="Enter the new date")][datetime] $NewPasswordDate)
$Status = (Reset-AdmPwdPassword -ComputerName $RealComputer -WhenEffective $NewPasswordDate).status
Write-Host "The new password date is $NewPasswordDate"
Sergio S.
SysArch
Hi Sergio
Thanks for your response but I think you misunderstood me. LAPS was just an example of an application that has a problem. There are several applications that have a problem with identical CNs. So I want to fix the problem at the source and not figure out a workaround for every application.
In addition, the overview in AD users and computers management console is poor if the support employee finds two identical computer objects.
WPort3
I am also running into this issue. Seems the identical CNs are in conflict with a our 3rd party whitelisting solution.
