Intel vPro® Platform
3059 Discussions
Intel SCS Hotfix 6.0.25.6 Error-- Module could not be found
I have install SCS 6.0.24 on SCS server , works OK,
When I tried to install Hot fix, I am getting error message saying" ....Module could not be found..."
PLEASE SEE SCREENSHOT AND ADVISE ME>
Soni
Please confirm you used Local admin rights to install the patch
Daniel_B_Intel1
Can you please provide us with some additional information:
1. What OS and service pack level is your SCS 6 running on?
2. Are you logged into the SCS server with the same user account used when SCS was originally installed?
3. When running the hotfix have you right clicked on the installation file and chose "run as administrator"?
Thanks...
I can see from the screen shot that you did not include the installation directory on the command line when running the install script.
This is outlined in the Hotfix documentation as:
Install_Patch.bat "C:\Program Files\Intel\AMTConfServer\Service\"
Try running it again.
