Intel vPro® Platform
Intel Manageability Forum for Intel® vPro Fleet Services, EMA, AMT, SCS & Manageability Commander.
3089 Discussions
Intel SCS - SCCM 2012 R2 SP1 Integration Issue
DFilh
The SCS add-on fail to install on SCCM 2012 R2 SP1.
Failure: Could not load file or assembly 'AdminUI.WqlQueryEngine, Version=4.0.6000.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35′ or one of its dependencies. The system cannot find the file specified.
The Console is installed.
Anyone?
AGrif2
I have logged a call directly with Intel as I have the same issue. Initially I thought it was a PATH variable issue, however if you place the referenced .dll in the same folder as the SCCMaddon application and rerun the wizard I get a different error.
2015-06-02 13:58:30,977 - INFO : - Failure: Could not load file or assembly 'AdminUI.WqlQueryEngine, Version=4.0.6000.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies. This assembly is built by a runtime newer than the currently loaded runtime and cannot be loaded. .
Did you ever resolve this issue? I will update this post once I hear back from Intel Support.
AFiel3
Hi there, any update from Intel support on this? Before I plan when to perform my upgrade I want to know I can succeed and is supported, thank you.
AFiel3
AGrif2
AFiel3
AFiel3
JRama1
Has anyone found a solution to this issue? I'm currently trying to install the SCS ADD-on and getting this error. I have already tried putting the SCCM Manager Console contents into the Add-on exe locations, but still get the same error as the OP.
JRama1
AFiel3
Hi all, bumping for an update? Will have to log an official question soon I think myself.
AFiel3
Dvand2
Has anyone had a fix for this? I am experiencing the same issue.
Dvand2
SG11
Any update on this issue?
AHaeb
On our system (Server 2012R2), SCCMAddon.exe run without errors after copying the 'missing' DLL into the same folder as SCCMAddon.exe and adding the bold line to SCCMAddon.exe.config:
<?xml version="1.0"?>
Andreas
AHaeb
Andreas
SG11
AHaeb
Andreas
AHaeb
Andreas
