Intel vPro® Platform
3045 讨论
Intel don't work after rename server et change ip
AGUNS
新手
3,500 次查看
Hello !
The intel ema server was working before making the name and ip change. The server is on windows server datacenter 2019.
When I try to access the server via the web interface, I get errors. I guess the problem is accessing the database (it's on the same server).
In C:\Program Files (x86)\Intel\Platform ManagerPlatform Manager Server\settings.txt I changed the old "emahostname" to the new server name but nothing changes.
In EMAServerInstaller.exe I tried to set the new server name to "database Server" but errors occurred and so the old server name remained.
When I access the database with the "sa" account using Microsoft SQL Server Management Studio, I have full access.
Thank you for your help,
Alexandre
0 项奖励
1 解答
5 回复数
AGUNS
新手
3,488 次查看
Other: the sa account for the sql database has the sysadmin role and I saw this in the doc:
"If the account used by the Intel EMA services is granted the sysadmin role, and that is later removed, access to the database will no longer work.".
I don't know.
0 项奖励
Victor_G_Intel
3,463 次查看
Hello AGUNS,
Please share with us the exact steps you used to change the EMA server’s IP and name? Also why did you need to change the EMA server's name and IP?
Victor G.
0 项奖励
AGUNS
新手
3,450 次查看
This is a vm that has been moved from one hypervisor to another.
The change of name and ip was done in the classic way via windows.
This was necessary and mandatory for the company's network policy.
Thank you for your reactivity,
Alexandre.
0 项奖励
Victor_G_Intel
3,334 次查看
Hello AGUNS,
Thank you so much for contacting Intel customer support,
We are glad to know that you found a solution. Since the thread is now solved, we will proceed to close it.
Victor G.
0 项奖励
回复
