Intel vPro® Platform
Intel Manageability Forum for Intel® vPro Fleet Services, EMA, AMT, SCS & Manageability Commander.
3088 Discussions
Invoke-GenerateCSR is not working
jic5760
I'm trying Invoke-GenerateCSR via PowerShell.
But not working...
1. Invoke-GenerateKeyPair -ComputerName localhost -Username admin -Password "XXXXX" -KeyAlgorithm RSA -KeyLength 2048
2. (Save public key as amt-public-key.pem)
3. create-amt-null-signed-csr -cn "test" > "C:\temp\csr.pem"
4. Invoke-GenerateCSR -ComputerName localhost -Username admin -Password "XXXXX" -SigningAlgorithm SHA256-RSA -NullSignedRequestPath "C:\temp\csr.pem"
Result:
Exception Thrown:
"1"개의 인수가 있는 "InvokeMethod"을(를) 호출하는 동안 예외가 발생했습니다. "ConnectionClosed"
translated:
An exception occurred while calling "InvokeMethod" with "1" arguments. "ConnectionClosed"
References:
https://github.com/rgl/create-amt-null-signed-csr
Lee.
jic5760
Hello, JoseH.
https://software.intel.com/sites/manageability/AMT_Implementation_and_Reference_Guide/default.htm?turl=WordDocuments%2Fchangesfromrelease100torelease110.htm
It seems that GeneratePKCS10RequestEx is deprecated.
I close this issue as we will not be using the deprecated one in the future.
Thank you
Lee.
JoseH_Intel
Hello jic5760,
Welcome back to the community
Could you please tell your OS version and PowerShell version? Remember that the OS needs to be installed in US English as per there is no internationalization support yet.
Jose A.
jic5760
Hello, Jose A.
Windows Version : 21H2 (OS Build: 19044.1706)
PowerShell Version ($PSversionTable):
Name                           Value
PSVersion                      5.1.19041.1682
PSEdition                      Desktop
PSCompatibleVersions           {1.0, 2.0, 3.0, 4.0...}
BuildVersion                   10.0.19041.1682
CLRVersion                     4.0.30319.42000
WSManStackVersion              3.0
PSRemotingProtocolVersion      2.3
SerializationVersion           1.1.0.1
The socket is closed when sending wsman XML requests with postman as well as PowerShell.
<?xml version="1.0" encoding="utf-8"?>
<Envelope xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:a="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:w="http://schemas.dmtf.org/wbem/wsman/1/wsman.xsd" xmlns="http://www.w3.org/2003/05/soap-envelope">
    <Header>
        <a:Action>http://intel.com/wbem/wscim/1/amt-schema/1/AMT_PublicKeyManagementService/GeneratePKCS10RequestEx</a:Action>
        <a:To>/wsman</a:To>
        <w:ResourceURI>http://intel.com/wbem/wscim/1/amt-schema/1/AMT_PublicKeyManagementService</w:ResourceURI>
        <a:MessageID>1</a:MessageID>
        <a:ReplyTo>
            <a:Address>http://schemas.xmlsoap.org/ws/2004/08/addressing/role/anonymous</a:Address>
        </a:ReplyTo>
        <w:OperationTimeout>PT60S</w:OperationTimeout>
    </Header>
    <Body>
        <r:GeneratePKCS10RequestEx_INPUT xmlns:r="http://intel.com/wbem/wscim/1/amt-schema/1/AMT_PublicKeyManagementService">
            <r:KeyPair>
                <Address xmlns="http://schemas.xmlsoap.org/ws/2004/08/addressing">http://schemas.xmlsoap.org/ws/2004/08/addressing/role/anonymous</Address>
                <ReferenceParameters xmlns="http://schemas.xmlsoap.org/ws/2004/08/addressing">
                    <ResourceURI xmlns="http://schemas.dmtf.org/wbem/wsman/1/wsman.xsd">http://intel.com/wbem/wscim/1/amt-schema/1/AMT_PublicPrivateKeyPair</ResourceURI>
                    <SelectorSet xmlns="http://schemas.dmtf.org/wbem/wsman/1/wsman.xsd">
                        <Selector Name="InstanceID">Intel(r) AMT Key: Handle: 0</Selector>
                    </SelectorSet>
                </ReferenceParameters>
            </r:KeyPair>
            <r:SigningAlgorithm>1</r:SigningAlgorithm>
            <r:NullSignedCertificateRequest>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</r:NullSignedCertificateRequest>
        </r:GeneratePKCS10RequestEx_INPUT>
    </Body>
</Envelope>
Lee.
JoseH_Intel
Hello jic5760,
There is an old issue about System cryptography > Use FIPS compliant algorithms for encryption, hashing, and signing.
Take a look at this article “WsmanUnauthorizedException” Error When Using PowerShell*... (intel.com)
Jose A.
jic5760
Hello Jose A.
That's different from the problem. It does not fail authentication.
Commands other than Invoke-GenerateCSR succeed.
And HTTP requests also fail, non-PowerShell.
Lee.
JoseH_Intel
Hello jic5760,
In the Release Notes for the PowerShell module v15.0.2.1 it says:
Intel vPro® Technology Module for Windows* PowerShell* 15.0.2.1
# This version includes new PowerShell cmdlets:
 1. TLS configuration scripts:
Invoke-GeneratePrivateKey
Invoke-GenerateCSR
Invoke-ConfigureTLSServerAuthentication
Invoke-ConfigureTLSMutualAuthentication
Invoke-DisableTLSAuthentication
Invoke-AddPrivateKey
Let me try to look more info about this particular command. I will get back to you soon.
Jose A.
JoseH_Intel
Hello jic5760,
We are unclear as to what you are attempting to do. We notice that you are using code from the github reference and not completely using the SDK? is this correct? Also, is this happening on multiple systems? Please run an SSU and a acuconfig.exe /verbose /output systemdiscovery and attach the ssu output and the .xml file to the case.
Attaching the "Intel vPro Technology module for Windows PowerShell - Rev 3_2_6" for reference on the particular command
Jose A.
jic5760
Hello, JoseH.
Thank you
Lee.
