Intel vPro® Platform
3046 Discussions
Is there a log somwhere for the Intel MC WoL Service?
HMads
I Installed the Intel Managebility Commander on a SCCM server. I get the service installed and running and the right click menu entries work fine.
Is there a log for the service that i can monitor to see if things are working as expected and for troubleshooting?
HMads
Hi...
Just wanted to add that i get a TLS protocol error 70 in the eventviewer when the service tries to wake a PC.
I think it's because TLS 1.0 is no longer supported.
I get the same error when i try to use the powershell module to connect to amt.
Is there a newer version of the poweshell module which supports newer TLS and maybe the service needs to be updates aswell?
Hello heinekmadsen,
Thank you for posting on the Intel ® communities.
I can see that you are looking for a way to monitor the system using the Intel ® Manageability Commander.
Regarding this, what I can recommend you to do, is to check the user guide which contains the features and what can be done with it, please refer to the link below:
https://www.intel.com/content/dam/support/us/en/documents/software/manageability-products/Intel_MC_User_Guide.pdf https://www.intel.com/content/dam/support/us/en/documents/software/manageability-products/Intel_MC_User_Guide.pdf
I hope this helps.
David V
Under Contract to Intel Corporation
Hello heinekmadsen,
I am following up with your case and see that we have not heard back from you.
Were you able to take a look at the user guide provided?
If you need more assistance do not hesitate to reply.
David V
