Intel vPro® Platform
3067 Discussions
Is there a way to provision the AMT via Powershell or Bios Update
Hello around.
I gotthe job to test VPro in an SCCM2007 R2 enviroment.
Unfortunatly i haven't worked with Vpro yet and find it a little confusing. Perhaps someone can show me the right path.
We have a PKI with client certificates running. At the moment we only need in-band managment. All clients are
managed via SCCM 2007 R2. I have found some videos showing how to filter the unprovisioned clients and provision them
via the Out-of-Band managment in SCCM. Question is how can i configure the AMT settings like Password, DNS, Hostname and so one
without touching every client. (We have 8000 at the moment)
Is there a way to change these settings with a Bios Update or a script?
I would be glad if someone could help me out.
Thank you
Tom
Hi Tombaer,
It may be easiest to just configure the machines using SCCM. Take a look at this technet article on SCCM Out of Band Management:
http://technet.microsoft.com/en-us/library/cc161989.aspx http://technet.microsoft.com/en-us/library/cc161989.aspx
Also, check out the Microsoft Manageability section on the vPro Expert Center:
/community/openportit/vproexpert/microsoft-vpro http://communities.intel.com/community/openportit/vproexpert/microsoft-vpro
And also the SCCM Specific Guides here:
/docs/DOC-1370 http://communities.intel.com/docs/DOC-1370
It is possible to configure via PowerShell, but it would be a somewhat complicated set of scripts that have to be executed.
To get started with the AMT vPro PowerShell Module:
/docs/DOC-4800 http://communities.intel.com/docs/DOC-4800
Hope this helps!
Josh
Hi Josh,
thank's for the links i think i will start some reading.
Tom
