Intel vPro® Platform
3044 Discussions
Issues with vPro on Lenovo T400
I am having issues with Lenovo Thinkpad T400 and the KVM feature in MEBX. The option does not show up like it explains in this use case: http://www.youtube.com/watch?v=v-X90NJ-I5I&feature=relmfu http://www.youtube.com/watch?v=v-X90NJ-I5I&feature=relmfu
When I run the .hta on the support end and point it to the ip address of the T400 and click "enable" I get the following error:
Output
WSManFault
Message = The client cannot connect to the destination specified in the request. Verify that the service on the destination is running and is accepting requests. Consult the logs and documentation for the WS-Management service running on the destination, most commonly IIS or WinRM. If the destination is the WinRM service, run the following command on the destination to analyze and configure the WinRM service: "winrm quickconfig".
Error number: -2144108526 0x80338012
WSManFault
Also I have confirmed that "winrm quickconfig" is running on both systems:
C:\Windows\system32>winrm quickconfig
WinRM already is set up to receive requests on this machine.
WinRM already is set up for remote management on this machine.
Does anyone know what I could be doing wrong?
What option is it that you are referring to?
On the youtube link there is a use-case download. In the PDF document under "3 Prepare The Managed Client" there is a setting called "Legacy Redirection Mode" that I cannot find under my MEBX nor is there a "KVM Configuration" section. Everything else in the use-case is there though.
The Lenovo T400 with AMT 4.2 does not have KVM.
The UCRD will only work with a system with AMT 6.0 and above.
