Intel vPro® Platform
Intel Manageability Forum for Intel® vPro Fleet Services, EMA, AMT, SCS & Manageability Commander.
3091 Discussions
ME error (during boot)
I'm a personal user of my Santa Rosa based laptop (ASUS V1S - BIOS ver 209).
I was totally new to the AMT, so I started to activate it, and installed the Vista drivers that eventually said it was activated and working. I'm not sure I had disabled it from the BIOS then, but I had no problem with it so far. I'm using the laptop all alone with an ADSL bridge that gives the LAN an IP address from DHCP. Also I have a docking station. (maybe these are important)
After a crash of Vista, today I discovered that I cannot any more enter the MEI area by pressing Ctrl+P, and during the boot process I can spot an error message in RED saying "ME error" for a couple of moments, then it goes loading Windows. Also, obviously the Vista drivers say it's not activated. I don't seem to have any problem other than is annoyingly doesn't work.
Can anyone give a clue how could I make it right, or to enter it again? I tried to update the BIOS, but no change in this functionality.
Thank you,
Attila
William_Y_Intel
It sounds like your ME firmware may need reset. A couple of things to try.
  1. You can see if you can go into the System BIOS to enable AMT or enable Ctrl + P for AMT. Some OEMs put these options in their system BIOS for AMT while others have no reference to AMT in the system BIOS. All OEMs are different.
  2. You could try and update the system to the latest BIOS to see if this recovers your ME. Again, all OEMs are different but many of them wrap up the latest AMT firmware in their BIOS updates.
  3. (This is not the easiest) but you can pull the cmos battery from your laptop and this will reset ME back to factory defaults.
I hope one of these options can recover your ME.
Thanks for the tips, however:
1. If I go back to previous BIOS, where I can disable/enable AMT; if I enable it's still the ME error, because the BIOS tries to run the AMT setup and fails.
2. If updated the BIOS - see above - went back and forth, no change.
3. Thanks! This is what I figured out from many documents as well, no I need to find out how can I open up the laptop and get my hands to the battery.
Can you by the way help with that? (Asus V1s)
I'll write if I tried option 3.
Do you know why this "ME error" could happen? Anyone? (I guess if I next time keep AMT disabled via BIOS it cannot happen?!)
hey wow
i have directly tha same problem with my ASUS V1S, it was working and all was fine, and then suddenly it started to make problems,
i noticed that the fan was working now all the time, so i updated the BIOS to newsest 301AS and all other drivers, now the fan works better, but i noticed performance dropdown (a graphic application was running 100frames (max), now only 30~64)
also i get the Intel ME error during boot and windows tells me :
Error
Symptom:
Cause:
A device has a configuration problem that prevents it from starting properly.
Details:
The
device, Intel(R) Management Engine Interface, cannot start properly. It
may not have the correct driver installed or may be experiencing a
hardware failure. The Plug and Play ID for this device is
PCI\VEN_8086-DEV_2A04-SUBSYS_15871043-REV_03\3-11583659-1-18.
Resolution:
1. Verify the correct driver is installed.
2. Try updating the drivers using Windows Update.
3. Check with the manufacturer for an updated driver.
4. Attempt to uninstall and then reinstall the device using Device Manager.
Related:
http://go.microsoft.com/fwlink/?LinkID=70093 Explanation of Error Codes Generated by Device Manager\
http://go.microsoft.com/fwlink/?LinkID=70092 Manage Devices in Windows\
Symptom:
Cause:
A device is disabled preventing it from working properly.
Details:
The
device, Intel(R) Active Management Technology - SOL, is disabled. If
this device is no longer used it may be intentionally disabled. The
PCI\VEN_8086-DEV_2A07-SUBSYS_15871043-REV_03\3-11583659-1-1B.
Resolution:
1. Determine if you need the device.
2. If you need the device, enable it in Device Manager.
3. If you do not use the device it can be left disabled.
Related:
if i try to reinstal the drive for Intel(R) Management Engine Interface from http://downloadcenter.intel.com/confirm.aspx?httpDown=http://downloadmirror.intel.com/14617/eng/HECI_AllOS_3.0.30.1086_PV.exe&agr=N&ProductID=2887&DwnldId=14617&strOSs=All&OSFullName=All%20Operating%20Systems&lang=deu
it tells me : The system doesnt meet the minimal requirements to install, setup will abort
what should i do? i dont want to open the nb and manipulate with hw (i would lost my warranty), and would it help either?
thank you
Brian_Cockrell
The driver that you are installing is available directly from ASUS and should recognize your system as meeting the minimum install requirements.
Go here: http://support.asus.com/download/download.aspx?SLanguage=en-us , select your system and then expand the "other" category. Download the "IAM_LMS Intel Active Management Technology Driver" and "IAM_ME Intel Active Management Technology Driver" and follow the installation instructions.
<![CDATA[after i install the drivers, all writes ok, but after reboot, it looks like this [http://politea.sk/tmp/Zwischenablage03.jpg]]]>
JoshHilliker
which exact system do you have? I believe there is a SOL driver you need to download & Update.
thats my nb, but i have installed the latest drivers from the asus support page...
Processor
Intel® Core™2 Duo Processor T7700 2.4 GHz, 800MHz FSB, 4MB L2 Cache)
1GB Turbo Memory
OS
Genuine Windows® Vista™ Business
Chipset
Mobile Intel® PM965 Express Chipset
Main Memory
2GB DDRII 667MHz, up to 4 GB
Display
15.4" WSXGA+ (16801050*) Color Shine LCD Zero Bright Dot ASUS Splendid Video Intelligence Technology
Video Graphics
NVIDIA GeForce 8600GT dedicated 512 VRAM, 768 Shared RAM
1.2 GB Total Video Memory, DX10
Hard Drive
2.5" 9.5mm IDE HDD /w Ultra DMA 100 / S.M.A.R.T. supported SATA 160 GB(5400rpm) Swappable hard-disk supports SATA
Optical Drive
8X DVD-Dual Light Scribe Support Module HOT Swap Function and 2nd HDD/Batt.
Card Reader
MMC/SD/Mini-SD/XD/Memory Stick/MS Pro/MS-Duo/MS-Pro-Duo
Video Camera
1.3 Mega Pixel Swivel web-cam
Fax/Modem/
* LAN/WLAN*
56K S/W MDC Fax/Modem (Motorola M3 Function supported)
On board 10/100/1000 Mbps Fast Ethernet Controller
Intel® 82566MM Gigabit Network Connection
Intel® Wireless WiFi Link 4965AGN Network connection
Built-in Bluetooth™ V2.0+EDR
Interface
1 x Express Card
1 x VGA port
1 x Headphone-out jack (SPDIF)
1 x Microphone-in jack
1 x RJ11 Modem jack for phone line
1 x RJ45 LAN Jack for LAN insert
3 x USB 2.0 ports, 1x IEEE 1394 port
1 x TV-Out
1 x E-SATA & USB combo port
1 x HDMI
1 x Docking Connector (hot swappable)
Audio
Built-in Azalia compliant audio chip, with 3D effect & full duplex
Built-in speaker and microphone
ADSP
Battery Pack & Life
8-cell, 5200mAh, 77Whr
Dimension & Weight
363 x 263 x25-35.7 mm, 2.4 kg
Keyboard
Spill-proof Keyboard with 87/88 keys
Does anyone find solution? I have similar problem with my V1S (it appeared after system was crushed). I update BIOS and AMT drivers, but there is no result. I also found http://vip.asus.com/forum/view.aspx?id=20071012215437500&board_id=3&model=V1S&page=1&SLanguage=en-us this on ASUS forum. Sorry for my English.
