Intel vPro® Platform
3060 Discussions
Maximum number of client connections when building an Intel EMA server with the minimum required res
M_T11
I am wondering if the official documentation will describe the resources required to build an Intel EMA server. (as shown in the following capture)
I think it says here “This configuration should be able to handle over 20k connections.” Is this the maximum number of client connections? If this is not the case, we would like to know what the upper limit is for the number of client connections.
The document can be downloaded from the following page.
「Intel EMA ServerInstallation MaintenanceGuide_Rev1.14.0.pdf」
https://www.intel.co.jp/content/www/jp/ja/download/19449/intel-endpoint-management-assistant-intel-ema.html#:~:text=%E3%82%A4%E3%83%B3%E3%83%86%E3%83%AB%C2%AE%20%C2%AE%20%E3%82%A8%E3%83%B3
Suneesh
Hello M_T11,
Greetings of the day.
We wanted to inform you that each endpoint requires 2 side connections, so the upper limit for client connections (endpoints) is 10K.
Suneesh
Suneesh
Hello M_T11,
Suneesh
IntelSupport
Community Manager
Hello M_T11,
Greetings for the day!!
I am just sending a follow up if you have any questions from the previous post. If so, please let us know.
Vishal
IntelSupport
Community Manager
Hello M_T11,
We just sending a follow up if you have any questions from the previous post.
If further assistance is necessary, do not hesitate to reply.
Vishal
