Intel vPro® Platform
3050 Discussions
Necessary modifications for TLS communication
watamaru2000
So far, I have been controlling the power of the PC from my custom application using the AMT SDK and non-TLS communication. In order to support TLS communication, can I just change the parameters of CimOpenWsmanClient() as follows? Also, do I need to worry about the version of AMT and TLS of the target connection (server)?
Current situation:
1. Use CimOpenWsmanClient() and specify 16992 and FALSE as the second and third parameters.
2. Use CIM_PowerManagementService RequestPowerStateChange() to get the power state.
3. Use CIM_AssociatedPowerManagementService PowerState() to change the power state.
Going forward:
1. Use CimOpenWsmanClient() and specify 16993 and TRUE as the second and third parameters.
Environment:
AMT SDK 16.0.4.1
MIGUEL_C_Intel
Hello, watamaru2000,
The TLS 1.2 is supported on endpoint machines with Intel® AMT version 12 and higher.  This technology is embedded in the chipset firmware of the systems.  Intel® Core processors 8th gen and newer supported it only.
The server machine and the operating system need to support TLS 1.2.
Miguel C.
Eduardo_B_Intel
Hello watamaru2000,
I would like to know if you have any additional questions related to our previous message, or if there is anything else I can do for you. I will monitor your case today and follow up on the 15th if needed. For anything else, let me know.
Warm regards,
Eduardo B
Intel Customer Support.
Eduardo_B_Intel
Hello watamaru2000,
I would like to know if you have any additional questions related to our previous message, or if there is anything else I can do for you. I will monitor your case today and follow up on the 20th if needed. For anything else, let me know.
Warm regards,
Eduardo B
Eduardo_B_Intel
Hello watamaru2000,
I would like to know if you have any additional questions related to our previous message, or if there is anything else I can do for you. Since there was no response for our previous messages, I will proceed to mark the case as resolved. If additional support is needed, please do not hesitate to let us know.
Warm regards,
Eduardo B
