Intel vPro® Platform
Intel Manageability Forum for Intel® vPro Fleet Services, EMA, AMT, SCS & Manageability Commander.
3092 Discussions
Problem getting a connection to vPro system
I'm running a vPro compatible system consisting of an Intel DQ57TM mainboard and an i5 660 cpu. At the moment there is no harddisc attached, but in my opinion this should be no problem.
I tried to configure the system as described here: http://communities.intel.com/docs/DOC-4795
When it comes to section 5 and I execute the kvm.hta on my laptop, I get the following message at step 2:
http://img59.imageshack.us/img59/5345/wsmanfault.jpg
I think this is the problem why I can not connect to the client using vnc viewer. By the way I am able to access the clients web interface with the following link: http://192.168.1.55:16992/index.htm, but logging in is also impossible.
Do you have any hints how to solve the problem?
Thanks a lot.
