Intel vPro® Platform
3080 Discussions
Reset configured AMT
SCCM_MKE_Admin
  I have inherited 20 Optiplex 7460 AIO workstations. However, these had been previously AMT configured but the bad part is nobody knows the passwords. It's not the default admin password. How can you reset the MEBx back to default if you can't get in it?
SCCM_MKE_Admin
Emeth_O_Intel
Hello SCCM_MKE_Admin,
The only way to change the default MEBx password across an enterprise (assuming all under the same domain) would be a remote configuration of AMT. Based on the description, I do not know whether or not you have already deployed AMT, so I'm providing the user guide for further details:
The SCS User Guide can be accessed at this link:
https://www.intel.com/content/dam/support/us/en/documents/software/Intel_SCS_User_Guide.pdf
Information on certificates needed for remote configuration can be accessed at this link:
https://www.intel.com/content/www/us/en/remote-support/intel-vpro-certificates.html
Intel recommends the following best security practices. Please find the document at this link:
ttps://www.intel.com/content/dam/support/us/en/documents/technologies/Intel_AMT_Security_Best_Practices_QA.pdf
Remote configuration is the only way to change the MEBx password for an enterprise, there are two other methods but require physical access to the systems, which would be inefficient in the case of an enterprise environment. Based on what I know so far, it sounds like you might be able to benefit from deploying AMT.
Emeth O.
Intel Server Specialist.
Emeth_O_Intel
I was reviewing the scenario and I like to suggest you to remove the CMOS battery or perform an NVRAM-Clear to reset AMT on these desktops.
Please let me know if the step helps you to reset the password.
Emeth O.
Emeth_O_Intel
I would like to know if the information provided helps you to solve the issue you have been facing.
If so, please let me know in order to proceed with the next step.
Emeth O.
Emeth_O_Intel
I was reviewing your thread and I have not seen any activity recently from your end. If you have more questions, please do not hesitate and let us know, and we will be more than happy to assist you.
Have a wonderful day.
Emeth O.
SCCM_MKE_Admin
