Intel vPro® Platform
Intel Manageability Forum for Intel® vPro Fleet Services, EMA, AMT, SCS & Manageability Commander.
3087 Discussions
RestAPI: Add userGroup members not working
Jools86
New Contributor III
Using the following POST method via PowerShell:
https://localhost/api/v5/userGroupMemberships/{userGroupId}/addMembers
I set the body as
$UPN=@()
$UPN+="[email protected]"
#// Add to User Group
$Body = @{
'UserName'=$UPN
$JSON=$Body | ConvertTo-Json
$UserGroup=Invoke-RestMethod "https://ema.mydomain.com/api/latest/userGroupMemberships/$EMAUserGroupId/addMembers" -Headers $headers -Body $JSON -Method Post
however I see this error every time:
I tried changing to
$UserGroup=Invoke-RestMethod "https://ema.mlp.com/api/latest/userGroupMemberships/$($EMAUserGroupId)/addMembers" -Headers $headers -Body $JSON -Method Post
and even changing to
$UserGroup=Invoke-RestMethod "https://ema.mlp.com/api/latest/userGroupMemberships/1/addMembers" -Headers $headers -Body $JSON -Method Post
Could you either:
a) Confirm there is a BUG in the RestAPI for adding members
or b) Send me an example if I am getting the syntax wrong.
As an FYI, token generates fine (code to generate headers below) - and I can run most other RestAPI queries using the below, its this specific one (https://localhost/api/v5/userGroupMemberships/{userGroupId}/addMembers) that is broken.
#// Generate token to be passed for authorization with each RestAPI request
$Token=Invoke-RestMethod "https://mydomain.mlp.com/api/latest/accessTokens/getUsingWindowsCredentials" -Credential $Cred
#// Generate header including token for each API request
$headers = @{
'authorization' = "bearer $($Token.access_token)"
Victor_G_Intel
Hello Jools86,
Please let me review this information internally, and kindly wait for an update.
Once we have more information to share, we will post it on this thread.
Victor G.
Intel Technical Support Technician
Victor_G_Intel
Hello Jools86,
Thank you so much for your patience.
After analyzing your request, we have come to the conclusion that this is not a bug, but a syntax issue. It looks like you are attempting to use an array $UPN=@()
Swagger syntax calls for the UPN to be a call for a "string"... "UserName": "string"
If you remove the array and turn it into a string it should work fine:
#Example
$UPN="[email protected]"
$Body = @{
'UserName'=$UPN
Write-Host $JSON
the output will look like as opposed to nothing in an array
  "UserName": "[email protected]"
Victor G.
Victor_G_Intel
Hello Jools86,
Please let me know if you need further assistance.
Victor G.
Victor_G_Intel
Hello Jools86,
We have not heard back from you.
Victor G.
