Intel vPro® Platform
3072 Discussions
SCS Add-on for MS SCCM 2012 - user account settings
JAdki
Hello, I am attempting to install the SCS add-on for SCCM 2012 and see a configuration setting in the setup that I do not understand. My question is related to the dialog box that asks for "User Account Settings". According the documentation it says this is for specifying a different user account for running the SCS packages through SCCM other than "the SCCM client". What does this mean?
The SCCM client by default runs packages under the local SYSTEM account when I runs a package on a client. Can I just leave this "User Account Settings" dialog box blank and not specify a "different user account"? It kind of implies this is an optional setting. If I do leave it blank and just use the default, are there any configuration settings I need to do to account for this? There is a chart in the documentation that specifies the permissions that are needed for the account that runs the packages, such as permissions to the ADOU and Intel_RCS/Intel_RCS_Editor namespaces. How do I (or do I need to) setup these permissions when the packages runs on a client as the local SYSTEM account.
Alan_A_Intel
While this is optional step, it is recommended to define a user account for this. If you decide to skip this and run packages under the local system account then you two options.
1. Give each of the system accounts permissions in the ADOU, CA, and Intel_RCS namespace.
2. Give the Everyone user account permissions in the ADOU, CA, and Intel_RCS namespace.
Alan_A_Intel
JAdki
thank you Alan, using a user account worked perfect me.
KKupr
Hi, Alan.
Can you explain the first option (1. Give each of the system accounts permissions in the ADOU, CA, and Intel_RCS namespace.)
What exactly should I add in the ADOU and so on? Domain Computers or somthing else? Because local system account (from SCCM Client) has no permissions on the RCS server...
