Intel vPro® Platform
Intel Manageability Forum for Intel® vPro Fleet Services, EMA, AMT, SCS & Manageability Commander.
3087 Discussions
Static IP Configuration using SCS 8.1
I'm trying to configure AMT 8.0 client(Intel's DQ77MK) via remote configuration using SCS 8.1. Configuring AMT with DHCP went successful, but AMT using static IP does not.
Target machine is running Windows 7 64bit, IP: 192.168.24.200, mask: 255.255.255.0 DNS 192.168.24.10, Gateway 192.168.24.5.
Do I miss something? Please, give me an advice.
The profile I used is as follows:
Profile2
Network Settings
FQDN will be the same as the Primary DNS FQDN
IP will be same as host (for static IP only)
Network Configuration
WiFi
Do not enable synchronization of Intel® AMT with host platform WiFi profiles
System Settings
Enabled Management Interfaces:
Web UI
Serial Over LAN
IDE Redirection
KVM
RFB password not defined
Timeout for user consent: 5 minutes
Power Management Settings: Always On (S0-S5), Timeout if idle: 10 minutes
Intel® AMT set to respond to ping requests
Fast Call for Help (Within the enterprise network) is Enabled
Server side Log (took this from database mode, monitoring->List of systems->my target machine ->
View Log)
Operation: Configuration - (Start)
Time and Date: 2012/09/28 14:08:04
Error code: 0
Severity: Information
UUID: 3D5DE29B-057D-E111-8B9D-505054503030
Intel AMT FQDN: http://dq77mk.vpro-lab1.vpro-amt.com/ dq77mk.vpro-lab1.vpro-amt.com
Intel AMT IPv4: 192.168.24.200
Server name: http://vlan24-scs81.vpro-lab1.vpro-amt.com/ vlan24-scs81.vpro-lab1.vpro-amt.com
Description: These parameters were given:
Profile Name: profile2
AMTVersion: 8.0.13
DedicatedFQDN: http://dq77mk.vpro-lab1.vpro-amt.com/ DQ77MK.vpro-lab1.vpro-amt.com
StaticIP: 192.168.24.200</s...
