Intel vPro® Platform
2780 Discussions
Trying to configure Remote configuration, almost there...
JHolm3
I have successfully provisioned a test machine (Dell OptiPlex 990, AMTv7.1) by entering the MEBX and choosing the option "Activate Network Access". I cannot seem to provision this machine with either acuconfig or the activator utility, without first manually choosing this option. Otherwise, I get errors in the logs regarding PKI certificates not being valid or connections to AMT not working.
I have a 2008R2 server with SCS 8.1 and a GoDaddy vPro cert installed. DNS is setup with provisionserver pointing to the IP of this server. The SOL driver and LMS service is installed on the target machine. The command line to configure (which works when the "Activate Network Access" option is selected in MEBX) is as follows:
C:\COnfigurator\acuconfig.exe /verbose ConfigViaRCSOnly scsserver.domain.net "Company Test Profile" /abortonfailure /adminpassword xxxxxxx
It seems that I am having trouble reopening the interface and entering setup mode? I thought the activator utility would help with this, but this also returns errors when run:
Step Into: CheckAMT
Connected to HECI driver, version: 7.1.70.1198
BIOS Version: A02
Intel AMT code versions:
Flash: 7.1.4
Netstack: 7.1.4
AMTApps: 7.1.4
AMT: 7.1.4
Sku: 24592
VendorID: 8086
Build Number: 1068
Recovery Version: 7.1.4
Recovery Build Num: 1068
Legacy Mode: False
Setup and Configuration:
In process
Provisioning TLS Mode:
PKI
Step Into: CSCSER::PerformSCSRemoteConfiguration
Step Into: CSCSER::SCSSetAMTIdentity
AMT version: 7.1 Step Into: StartConfiguration
BIOS Version: A02
Flash: 7.1.4
Netstack: 7.1.4
AMTApps: 7.1.4
AMT: 7.1.4
Sku: 24592
VendorID: 8086
Build Number: 1068
Legacy Mode: False
In process
Intel AMT Mode:
Non Legacy
Remote Configuration:
enabled
PKI
RNG seed status:
exists
PT_STATUS_INVALID_PT_MODE: Command is not permitted in current operating mode.
Activate Intel AMT configuration:
failure
PT_STATUS_INVALID_PT_MODE: Command is not permitted in current operating mode.Step Into: StartConfiguration
Step out: StartConfiguration error 3
After StartConfiguration 3
Step Into: CheckPKIPPSPIDStatus
Step out: CheckPKIPPSPIDStatus error 0
Connect to : at port: 9971:Unable to connect to server! ()
Sending the hello message has failed!
