Intel vPro® Platform
Intel Manageability Forum for Intel® vPro Fleet Services, EMA, AMT, SCS & Manageability Commander.
3088 Discussions
Unprovision AMT Locally
I am interested in a method of unprovisioning an AMT device locally, either via the HECI driver, or through the Local Manageability Service (LMS) interfaces. There are situations where I am unable to authenticate to an AMT device, even though I am still able to remotely manage the system at the application layer. This usually occurs if the system was partially provisioned, but didn't complete properly, or something similar.
I looked at the unprovisionex utility, and played with it a little, and I've used it before successfully, but only when I knew the credentials to connect to the system. I was hoping that an administrator could execute something to initiate erasage of the provisioning data on a local system.
Trevor Sullivan
Systems Engineer
OfficeMax Corporation
Matthew_R_Intel
The ability to unprovisioning locally does not exist with the currently released AMT firmware versions; this restriction was done as a security measure. Only local method for unprovisioning is to log into the MEBx (pressing control-p during boot) on the client and performing the unprovision from within there.
--Matt Royer
