Intel vPro® Platform
3072 Discussions
Using Intel EMA to configure AMT with Kerberos
The-Penguin
I'd been using SCS to configure AMT for a long time until it stopped working correctly after a security update to Active Directory stopped it being able to create computer accounts with a $ in the name. Moving on and looking at Intel EMA, it seems to work quite well, except I can't find a way to configure the AMT devices for Kerberos Authentication like we had with SCS.
In short, is Intel EMA able to configure an AMT Endpoint for Kerberos Auth? I know the EMA portal itself supported Integrated Auth and that's working, but how about for the actual endpoints?
Cheers
Victor_G_Intel
Hello The-Penguin,
To continue with your request can you please provide the following:
  1. How many endpoints does your Intel® EMA deployment have?
  2. What version of EMA is currently being used?
  3. Is this for a new deployment or an already existing one?
  4. Do you know the AMT version that your endpoints currently have?
Victor G.
Intel Technical Support Technician
The-Penguin
At the moment we only have it installed on around 10 machines for testing, but if we go ahead with it for our full fleet it will be around 150 devices.
We're running EMA 1.7.1, as we still have a few machines that are running v11.8 of the AMT Firmware. The majority of endpoints are running v12.
I guess it's kinda both a new and existing deployment. It's a new EMA deployment for testing, but we are coming from an SCS deployment where machines provisioned by SCS work with Kerberos as we require.
Victor_G_Intel
Hello The-Penguin,
Thank you so much for your response,
We appreciate the information provided. According to our Intel® Endpoint Management Assistant (Intel® EMA) Single Server Installation and Maintenance Guide, page 2. Section “Before You Begin” mentions that before you install EMA you need to decide whether you plan to install it under domain authentication mode (Kerberos) or normal account (username/password) mode, which is the default. If you need to use domain authentication, what we suggest is using the FQDN of your machine for the hostname; however, you still need to make sure that other endpoints or other client web browsers can connect to the value you entered. If you decide to use another value, you will need to follow IT practice to set up the Service Principle Name (SPN) after Intel EMA is installed.
Victor G.
The-Penguin
I'm aware of that and we have done that, but that is only for authenticating to EMA itself. What i'm looking for is a way to configure the Intel AMT profile for Kerberos Authentication.
Victor_G_Intel
Hello The-Penguin,
Please let me review this information internally, and kindly wait for an update.
Once we have more information to share, we will post it on this thread.
Victor G.
Victor_G_Intel
Hello The-Penguin,
Thank you so much for your patience.
I will be sending you some information via private message; therefore, please continue replying through that private message thread until I decide is okay for us to continue the communication through the forum.
Note: Please do not reply to this message.
Victor G.
Victor_G_Intel
Hello The-Penguin,
Were you able to check the latest private message we sent? Feel free to reply back to that private message if you need anything else.
Victor G.
Paul_R_Intel
Hello The-Penguin,
We are wondering if our help is still needed. If we do not hear from you will proceed to close the ticket in 2 business days.
Paul R.
Victor_G_Intel
Hello The-Penguin,
We have not heard back from you.
Victor G.
