Intel vPro® Platform
VT-d in DX58OG
currently i use a ASUS P6T which has also the X58 chipset.
While researching about VT-d usage with XEN i found out that ASUS is too incompetent to deliver a functional BIOS.
http://wiki.xensource.com/xenwiki/VTdHowTo http://wiki.xensource.com/xenwiki/VTdHowTo
Now I am faced with the decision which mainboard I should buy.
The question is which delivers actually working VT-d support.
Currently I tend to the DX58OG.
I would appreciate substantiate http://dict.leo.org/ende?lp=ende&p=HpZR0yYAA&search=substantiated&trestr=0x8004 d information on this matter.
thanks http://dict.leo.org/ende?lp=ende&p=Ci4HO3kMAA&search=in&trestr=0x8004 http://dict.leo.org/ende?lp=ende&p=Ci4HO3kMAA&search=advance&trestr=0x8004 in advance
Salem_W_Intel1
I confirm the Intel(R) Desktop Board DX58OG is not among the boards that feature/support Intel(R) Virtualization Technology for Directed I/O [Intel(R) VT-d]; see the following URL for more details:
http://www.intel.com/support/motherboards/desktop/sb/cs-030922.htm http://www.intel.com/support/motherboards/desktop/sb/cs-030922.htm
this cant be true.. there is no board which supports the 1366 socket?
and why does this sheet state that the X58 chipset supports VT-d?
http://www.intel.com/Assets/PDF/datasheet/320838.pdf http://www.intel.com/Assets/PDF/datasheet/320838.pdf 1.1.8
Salem_W_Intel1
I confirm the .pdf document you refer to is for the chipset. VT-d is a feature of the chipset, not the board; thus, while the chipset supports it, the board does not.
the DX58OG is now listed as compatible.
Was this through a recent bios update?
