Intel vPro® Platform
2779 Discussions
Vmware on nehalem - Is this perfect solution ?
Is running VMware next generation on Nehalem chip sets the perfect solution for enterprise
JLodh
New Contributor II
Nehalem architecture can be put to best use when it comes to virtualization and you get the provisioning of running various virtualization softwares such as Hyper-V, Citrix XenServer, VMWare and many others. However one can never say that VMWare would be the perfect solution cause any solution that meets the customer requirements and expectations and that is customized intelligently will turn out to be the perfect solution for the customer.
So VMWare on Nehalem can be the perfect solution for you and your customer but only if you design and customize your solution accordingly and it meets yours requirements, yes it can be the perfect solution.
Warm Regards,
Javed Lodhi
Intel Go Green, Save The Environment!
Javed ,Thank you so much for your response.
JLodh
New Contributor II
Glad to be of any help
Warm Regards,
Javed Lodhi
