Intel vPro® Platform
Intel Manageability Forum for Intel® vPro Fleet Services, EMA, AMT, SCS & Manageability Commander.
3088 Discussions
Vpro with Linux Redhat OS
Sebasboss
We have about 150 Dell Precision 3450 that runs RedHat 8.5 Operating System and equipped with Intel vPro AMT. We want to manage Poweron and off remote.
Does this technology support Linux Redhat OS?
If so I would like to have some documentation on how to proceed.
Thank you!
JoseH_Intel
Hello Sebasboss,
Thank you for joining the Intel community
Since your system is AMT capable it could be remotely managed using a suitable software. The Intel official current management software is called Intel® Endpoint Management Assistant (Intel® EMA). This software needs to run on Windows OS, but the client system that will be remotely managed could be running whichever OS as per the Management Engine is transparent to the system OS.
For more introductory info you can look the following video-tutorials
Intel® Endpoint Management Assistant (Intel® EMA) Video Series
Alternatively some 3rd party opensource softwares could be used. One of them is MeshCentral
Hope this helps
Jose A.
JoseH_Intel
Hello Sebasboss,
Hope this helps
Jose A.
JoseH_Intel
Hello Sebasboss,
I am just following up to double-check if you found the provided information useful. If you have further questions please don't hesitate to ask. If you consider the issue to be completed please let us know so we can proceed to mark this ticket as resolved. I will try to reach you as a very last time on next Tuesday 1st. After that we will mark the thread as closed
Jose A.
JoseH_Intel
Hello Sebasboss,
We will proceed to mark this thread as closed. If you have further issues or questions just go ahead and submit a new topic.
Jose A.
Mr_vPro
Sebasboss,
Intel® EMA  requires its EMAAgent.exe to be installed on endpoints.
Currently Intel® EMA Agent supports only MS* Windows OS.
As Jose pointed you may consider MeshCentral or Open AMT Cloud Toolkit  those tools support Linux OS.
Please look also at MeshCmd
it has Linux version and allows you to simply configure Intel® AMT into Client Control Mode  and reconfigure it if already configured to Admin Control Mode  for example by using USB Local Configuration with  USB File Tool from Intel® AMT SDK.
If you need more help on USB Local Configuration / MeshCmd contact me.
BTW  if your Dell Precision 3450 are equipped with discrete graphics that is able to run in Hybrid mode (sending rendered screen through Intel processor integrated GfX - you will be even able to use Intel® AMT HW KVM with it up to 4k resolution (I have w customers runinng it). Bare in mind that there is need to use dummy USB-DP plug to simulate Display presence (raise Display presence signal up) or check with Dell their latest BIOS for RC6 disable (Render Standby).
rgds
Dariusz Wittek
Biz Client Technical Sales Specialist  |  Intel EMEA CCG Technical Sales
Intel Corporation  |  intel.com
jasonkeltz
Hey Seabasboss,
I have a bunch of Dell Precision 3660's (with Intel on-board graphics and nvidia discrete graphics), and wondering if you managed to find these BIOS options to solve the problem, and get remote access to your desktops?  Not sure if you have discrete graphics.
Jason.
