Intel vPro® Platform
3056 Discussions
Website blank after Change IIS User Account
Stef37
As described in Intel's instructions, I changed the service account for IIS. However, the website remains white, and no errors are visible in the log files.
The Service "Intel® EMA Platform Manager" not starting and on Event viewer i find this event:
The Intel® EMA Platform Manager service terminated unexpectedly. It has done this 23 time(s). The following corrective action will be taken in 60000 milliseconds: Restart the service.
If I grant the service user local administrator rights, it works again. I conclude that some write permissions to a file/folder are required.
Does anyone have a tip or idea as to why the service user isn't working properly?
According to Intel, the following adjustments are necessary:
To do this, follow the steps below:
1. Give the account access to Intel® EMA assets (files and folders, certificate's private key).
a. Skip these steps if the account already has the necessary privileges. Intel® Endpoint Management Assistant (Intel® EMA) May 2025 Server Installation Guide Intel® EMA Server Installation R Guide—Introduction 22 Doc. No.: , Rev.: 1.14.3
b. If the SQL connection is using Windows authentication, ensure the new IIS user account satisfies the permission and role requirements for the SQL Server account. Refer Modify Permissions of SQL Server User, if Desired on page 27.
c. Change the service to run under the desired account.
d. Give read and write access to [System drive]\Program Files (x86)\Intel\Platform Manager\EMALogs.
e. Give full control to the following:
• [System drive]\inetpub\wwwroot: also for all sub-folders and files.
• [System drive]\inetpub\wwwroot\web.config
• [System drive]\Program Files (x86)\Intel\Platform Manager\Runtime\MeshSettings\app.config
• [System drive]\Program Files (x86)\Intel\Platform Manager\Runtime\MeshSettings\connections.config
• [System drive]\ProgramData\Intel\EMA\USBR - Or the USBR image path if you have updated it as described in Manageability Server on page 90
f. Use the Windows certlm tool to open the certificate store for Local Computer \Personal\Certificates and give "read" permission for the following certificates by right-clicking the target certificate and selecting All Tasks\Manage Private
Keys:
• Temporary Web TLS certificate. "Issued To" is the Intel® EMA web site FQDN or IP. "Issued By" is "MeshRoot-XXXX".
• Settings certificate. "Issued To" is "MeshSettingsCertificates-**bleep**". "Issued By" is "MeshRoot-XXXX".
• Inter-component TLS certificate for web server. "Issued To" is "EmaMtlsWeb-**bleep**". "Issued By" is "MeshRoot-XXXX".
2. Add a new IIS application pool for Intel® EMA.
a. Use IIS Manager to create a new app pool.
b. Choose .NET CLR Version v4.0.**bleep**, Integrated pipeline mode, and Start app pool immediately.
3. Assign an account to the new application pool.
a. Use IIS Manager to change the account for the new app pool.
b. Choose Custom Account and specify the desired Windows account.
4. Use IIS Manager to change the application pool used by Intel® EMA to the new one created above. Then restart the whole web site. For verification, access the Intel® EMA web site in a browser, then use Windows Task Manager to verfiy that the w3wp.exe process is running under the specified account.
Stef37
Hi Arun
Thanks for the remote session. Unfortunately, it didn't solve the problem.
I didn't understand much of what was said. I'll have to figure out how to solve the problem myself. At least if the wwwroot folder wasn't deleted after restarting the service or server.
Stefan
Arun_Intel1
Hi Stef37,
Thank you for joining the meeting!
Sorry to hear that the information provided has not been much useful, however there are few product limitations as well for which the guide provides certain protocols that needs to be followed.
Referring to section 1.3.3, in the server installation guide, kindly refer to the database section which would be helpful for your clarification.
https://www.intel.com/content/www/us/en/content-details/841803/intel-endpoint-management-assistant-intel-ema-server-installation-and-maintenance-guide.html
Note:
Before installing Intel® EMA, ensure that the SQL account used in the Intel® EMA SQL connection string to create the database has sysadmin rights (to create new account for IIS default application pool identity) and has at least dbcreator permission, which allows it to create, modify, and delete any database. Also, this account must have the database level roles db_owner, db_datawriter, and db_datareader. The “sysadmin” right is needed in order to create the new user “IIS APPPOOL\\DefaultAppPool\” for the SQL server (if it does not exist). If it exists already or you do not use that account for the IIS application pool of the Intel® EMA website, then the role needed during installation is “dbcreator”, to create the Intel® EMA database. Keep in mind that the “sysadmin” or “dbcreator” rights are only needed during Intel® EMA installation. Lastly you must grant permission for "SUBSCRIBE QUERY NOTIFICATIONS" to the user of Intel® EMA database.
Changing the IIS User account is a little complex.  The service account user needs to have access to the main SQL database. In addition, the admin user needs to give him rights to the EMA database.
The lines below describe the steps that the admin user needs to perform in SQL for adding a service account user with EMA database access.
Open the Security folder
         Right-click over the Login folder
         Select New Login
On the General tab
Login Name
                   Type Service Account User domain\username
At the bottom, for Default Database: Select EMA database
On Server Roles
         Add sysadmin
On User Mapping
         Check EMADatabase. In the same row, type dbo at the Default Schema.
On Securables
         No changes are necessary
On Status
         Grant permission to the database and enable login
Restart the server
Log in with the service account user to the server; he should have access to the EMA database.
Hence, as per the engineering suggestion, it is recommended that the user who accesses the EMA console, keep the admin rights to the database. This is suggested to prevent access issues after EMA software upgrades.
Thanks & Regards
Arun
intel.com/vPro
Stef37
Hello Arun
We're going around in circles, or they don't understand exactly what problem I have.
The adjustment was made on the SQL Server (external server, MS SQL Standard) as described in the instructions.
A new application pool with the service user was created in IIS and assigned to the website.
When I now call the URL, only a white website appears >I haven't logged in anywhere yet! The website is accessed either directly from the server or from a client in the internal LAN.
As already mentioned, the "Intel® EMA Platform Manager Service" service is not running, and I can't start it either.
If the service user is now added to the local Administrators group, the website appears and you can log in.
From an IT perspective, I should leave the service account in the local Administrators group unless the entire contents of wwwroot are deleted after a server restart (or the Intel® EMA Platform Manager Service is sufficient).
With this behavior, using Intel EMA is not possible.
Does the service user have to be in the local Administrators group? If so, what needs to be adjusted to prevent the contents of wwwroot from being deleted?
Or is this a bug and will be fixed in the next version?
Using it under the current circumstances is highly questionable.
Stefan
Arun_Intel1
Hi Stef37,
An email has been sent to your email id, with the meeting link for Wednesday as requested.
Kindly acknowledge through the email for confirming the meeting.
Thanks & Regards
Arun
Arun_Intel1
Hi Stef37,
Thank you for your email reply!
We see your note in the email which say that you have performed a fresh installation and as soon as the service user is in the server's local administrators group, it works, where the issue has been resolved.
Please feel free to revert for any further query!
Thank & Regards
Arun
Stef37
Hi Arun
The problem hasn't been resolved!!
You still don't seem to understand me:
The exact same problem still exists. If the service user is in the local administrators group, everything seems OK (the website appears and the user logs in correctly).
However, when the server or the Intel service is restarted, the entire contents of wwwroot are deleted.
I showed the technician this exact thing during the remote session last week, but no one was interested.
The product isn't usable in this way, or rather, a script must be developed that repeatedly checks the contents of wwwroot.
Stefan
Arun_Intel1
Hi Stef37,
We have informed the same to our business unit and can arrange for a specialist to join the meeting this time, kindly let us know your availability so that we can go ahead and schedule the call for the same.
We wanted to make sure that we are providing the best service possible for our customers.
Your understanding is greatly appreciated in this matter!
Thanks & Regards
Arun
Stef37
Hi Arun
Next week Monday or Tuesday afternoon is possible for me.
Stefan
Arun_Intel1
Hi Stef37,
​Our next week morning availability is tight. We will be available on Thursday, Sept 3rd, at 5 PM Switzerland (8 AM US PST).
We created a lab recently, and the configuration was successful. One big thing we saw in your environment. The entire contents of wwwroot are deleted after a server restart". We spoke with some of our developers, and that’s not a symptom we have ever seen. Wondering if you have some group policy, security software, etc, that is unique to your environment and wipes and/or redeploys apps/sites.
Lab details:
EMA software was installed, endpoint provisioned, and tested in-band and out-of-band KVM without any issues.
I’ll list the steps I used at the bottom of this email; there may be other options that would work, but this worked in my test AD environment.
Steps I used to install EMA and change the Platform Manager and IIS service account to a non-admin account
Environment:
  • EMA 1.14.3 was reinstalled.
  • 2 Win 2022 Servers: 1 application server, 1 running SQL Server 2022 Express
  • Traditional Active Directory running in an environment
Created a new EMA service account user in Active Directory
To perform initial installation and setup, logged into both servers as a Domain Admin account
On the server running SQL Server
  • Installed SQL Server 2022 Express and SQL Server Management Studio
  • In SSMS:
    • Created two SQL Authentication accounts on the SQL Server, one for the installer (with sysadmin rights) and one with no rights other than default rights.
    • Configured the default SQLEXPRESS instance created at install to allow SQL authentication in addition to Windows authentication
  • In SQL Server Configuration Manager, enable TCP/IP configuration and set the TCP/IP port to 1433.
On the EMA application server:
  • Ran the EMA server installer wizard
    • Choose the initial install for the Distributed Server
    • For database setup, specify the remote database
    • Choose SQL Authentication and provide the SQL Authentication accounts created above
    • Use FQDN first for Swarm Server Load Balancer, and provide the Server’s FQDN and IP address. Used “Same as Swarm Server” for the remaining load balancers.
    • Deployed all Server Components
    • Chose domain authentication
    • Completed the wizard and allowed the server to install
  • In certlm.msc, under Certificates - Local Computer > Personal > Certificates
  • For every certificate issued by MeshRoot or EmaPlatformManagerRoot, the AD service account has “Read” access to the private key:
      • Right-click on each certificate, choose “Manage Private Keys”, add the AD service account, and grant “Read” access
    • You can exclude EMAPlatformManagerRoot (where this is not an available option)
  • In Local Security Policy, under Local Policies > User Rights Assignment, find the “Log on as a service” policy, and add the AD service account.
  • Give full control to the AD service account for the following folders and their descendants:
    • [System drive]\ProgramData\Intel\EMA\USBR {Or the USBR image path if you have updated it)
  • At the command line, as administrator, run these commands (In this example, ‘KTG\ntservice’ is the AD service account to be used for the IIS AppPool and the Platform Manager service logon.)
Back on the server running SQL Server:
  • In SSMS, granted the SQL authentication service account db_owner access to the EMADatabase, in addition to the already existing access
  • Updated the account running Platform Manager
    • Find Intel Platform Manager in Windows services and change the user account under which this service is running
    • Restart the Platform Manager service
  • In Task Manager, end all “Intel® EMA” component server tasks – AJAX, Manageability, Recovery, Swarm -- Platform Manager will restart them.
    • Don’t kill Platform Manager itself here – it can’t restart itself .
  • Changed the account running the EMA web application in IIS:
  • Add a new IIS application pool for Intel® EMA.
      • Use IIS Manager to create a new app pool.
    • Choose .NET CLR Version v4.0.XXX, Integrated pipeline mode, and start the app pool immediately.
  • Assign an account to the new application pool.
      • Use IIS Manager to change the account for the new app pool.
    • Choose Custom Account and specify the desired Windows account.
    • Use IIS Manager to change the application pool used by Intel® EMA to the new one created above. Then restart the whole website.
    • For verification, access the Intel® EMA website in a browser, then use Windows Task Manager to verify that the w3wp.exe process is running under the specified account.
We look forward to your availability.
Thanks & Regards
Arun
Stef37
Hi Arun
Thank you very much for the information.
I still feel like I'm not being understood.
The steps I performed correspond to the steps listed. However, I have MS SQL Server Standard 2019.
Furthermore, I don't have a group policy that deletes the contents of the wwwroot folder. The contents are only deleted if I add the service user to the local administrators group.
If I don't add them there, the website remains white (meaning no login to the website is possible).
Furthermore, the Intel® EMA Platform Manager service doesn't start if the service user isn't in the local administrators group.
Stefan
Arun_Intel1
Hi Stef37,
Thanks for sharing your observation.
We are working upon the issue and will get back with an update asap.
Thanks & Regards
Arun
Arun_Intel1
Hi Stef37,
Thank you for your patience!
We would like to connect with your through a meeting, please find the available timings given below and share the best one according to your availability, so that we can share the meeting link through the email for the same date and time.
Thursday 11th, 9 AM PST (6 PM Germany)
Tuesday 16th, 7 AM PST (4 PM Germany)
Wednesday 17th, 7 or 8 AM PST (4 or 5 PM Germany)
Thanks & Regards
Arun
intel.com/vPro
Stef37
Hi Arun
The only possible date for me would be Tuesday, September 16, 2025.
Kind regards,
Stefan Heeb
Arun_Intel1
Hi Stef37,
Sure, we shall go ahead and arrange for a meeting on Tuesday 16th, at 7 AM PST (4 PM Germany).
We will share the meeting request through the email.
Thanks & Regards
Arun
intel.com/vPro
