Intel vPro® Platform
3052 Discussions
Where can change WEBUI account/password in Enterprise provision(PKI) through SCS11?
LS3
If using 16992 provision, the login account/password of WEBUI will be admin/P@ssw0rd.
But I'm wondering if I'm using 16993 provision, where can modify WEBUI account/password? ACS in SCS console? or ??????
Thanks~!
Hello hijasonkidd,
Regarding your question, Where to modify the username and password when using 16993.
According to the manual
https://www.intel.com/content/dam/support/us/en/documents/software/Intel_SCS_User_Guide.pdf https://www.intel.com/content/dam/support/us/en/documents/software/Intel_SCS_User_Guide.pdf
You should be able to manage the username and password at the NetworkSettings.xml.
I will check futher on this to see if I can find a better answer for you.
If there is anything else we can help please feel free to ask.
Henry A.
LS3
Thanks for reply.
Not sure if we add account in Access Control List can also change the account/password for WEBUI?
Hello hijasonkidd,
The access to WebUI should have no problem using AMT after 6.0.
Port 16993 is the correct port to use if you have enabled TLS in their profile (see section 5.10 of the SCS User Guide or section 4.10 of the AMT Configuration Utility User Guide). If TLS is not enabled, then you have to use 16992.
Henry A.
LS3
Dear,
Yes, if we're 16992 provision then the WEBUI login account will be "admin", password will be MEBx password like 1qaz@WSX.
But if provision 16993 through SCS, where can change the WEBUI login account/password ?
Thanks~!
Hello hijasonkidd,
Yes, the username and password should be the same on the both ports..
Henry A.
Hello hijasonkidd,
I will to follow up on this threat. I will like to verify if there is anything else I can help you.
Henry A.
Hello hijasonkidd,
I am sorry but we haven't heard any updates from your side.
I will proceed with closing the threat.
If you have any additional questions please open a new threat and just mention this threat for futher assistance.
Henry A.
