Intel vPro® Platform
3046 Discusiones
can't enable AMT on my laptop
Empleados
1.852 Vistas
I enable the AMT in BIOS (thinkpad t61p), and setup the AMT use DHCP (by Ctrl+P), the DHCP server is on my router, So in the router's webpage, I found a 192.168.1.2 is allocated as below:
INDEX MAC IP
1 00:1E:37:D2:FE:C1 192.168.1.2
But I can't access http://192.168.1.2:16992/ or https://192.168.1.2:16993/
In windows xp, the ethernet is a static IP 192.168.1.100, and The AMT startup Icon still report "AMT : Disable"
Description . . . . . . . . . . . : Intel(R) 82566MM Gigabit Network Connection
Physical Address. . . . . . . . . : 00-1E-37-D2-FE-C1
Dhcp Enabled. . . . . . . . . . . : No
IP Address. . . . . . . . . . . . : 192.168.1.100
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
all driver installed, meinfowin.exe dump as
Intel(R) MEInfo Win Version: 2.5.0.1034
BIOS Version: 7LETB7WW (2.17 )
Intel(R) AMT code versions:
Flash: 2.6.3
Netstack: 2.6.3
Apps: 2.6.3
Intel(R) AMT: 2.6.3
Sku: 12
VendorID: 8086
Build Number: 1032
Recovery Version: 2.6.3
Recovery Build Num: 1032
Legacy Mode: False
Link status: Link up
Cryptography fuse: Enabled
Flash protection: Enabled
Last reset reason: Power up
Setup and Configuration: Not started
BIOS Mode: Post Boot
Dedicated Mac Address: 00-1e-37-d3-fe-c1
Host Mac Address: 00-1e-37-d2-fe-c1
FWU Override Counter: Always
FWU Override Qualifier: Restricted
FW on Flash Desc Override: Disable
Kedron Driver Version: Not Available
Kedron HW Version: Not Available
UNS Version: 2.6.8.1025
LMS Version: 2.6.11.1025
HECI Version: 2.6.30.1014
How to ENABLE the AMT and access config web(16992) ?
0 kudos
1 Responder
Empleados
705 Vistas
According to the meinfowin output you posted, your AMT device has not been provisioned yet. You must provision the device before you are able to access the web interface, or any of its other features.
"Setup and Configuration: Not started"
Trevor Sullivan
Systems Engineer
Responder
