Intel vPro® Platform
3065 Discussions
help installing vista on new pc
i rebuilt my desktop with a dg45ID motherboard and a core2duo proc as well as a new motherboard and i am trying to install windows vista and i am in the first step where it is trying to get info and install drivers. the problem is that it does not find any driver software and i cannot complete the instalation
Ermm at what point exactly is this you will need to give a better description...Do you mean after the first login, when you need to install all the driver? If so then all the drivers are here:http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+4+Series+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+DG45ID
Otherwise, do you mean when you need to actually choose the dHDD you are installing it on? If so go in to BIOS and set SATA as IDE.
